Question about Mitsubishi WS-55711 55" Rear Projection Television
Device selection button locks up TV and after a few minutes turns TV off. Device selection does not function
  • John Snow
    John Snow May 11, 2010
    What is the model number of your set, and does the menu come up? Also, when you press channel up and down, what happens.
  • 556 Answers
With the remote press menu2 4 7 0 enter this should reinitialize set when it has reinitialized push reset button on front panel this should cure it. You will have to reprogram your channels and net command though.
Posted on Aug 14, 2009
Have not been able to get it to work to turn TV on & off and on sound---
Try by set it up with an other set-up code said for your device brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list,
use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code
in the code list that performs more functions. Try other codes from the code list for more functionality.
PROGRAMMING PROCEDURE
Direct Code Entry
Locate the Remote Code List provided in this manual. Find the DEVICE CATEGORY you wish to program (for
example TV, CBL,
DVR, DVD, SAT, AUDIO, AUX1, AUX2) and then find the BRAND of that device. Circle all the codes under that
brand. Example: For a GE TV, locate the TV code section then circle all of the GE TV codes.
Manually turn on the device you wish to control.
Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the SETUP button.
Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2). The
red indicator will blink
once and then remain on.
Enter the first 4-digit code previously found in the code list using the number buttons on the remote. If the code
entered is a valid code, the
red indicator light will turn off. If the code entered is not a valid code, the red indicator light will flash and remain on
allowing you to re-enter the code.
[If no buttons are pressed for 35 seconds, the remote will exit the SETUP mode and you will have to start over.]
Point the remote at the device. Press the POWER button, if the device turns off, no further programming is required
for that device. If the device does not turn off, return to step 3 and use the next code found in the code list. Continue
this process until a code for your device is found.
To view a helpful demonstration video for programming your ONN remote, see QR code.
• You can use any device button to control other devices in your home entertainment system. For example, you can
use the AUX1 device
button to control an audio receiver or a DVD, VCR, satellite, etc.
• For combination devices, you may have to enter a code for each device. For example, for a VCR/DVD device, you
may have to enter a
code for the DVD under the DVD button and enter a code for the VCR using a different device button on the remote.
• Write down the code found to operate your device for future reference.
Auto Code Search
The Auto Code Search searches automatically through all of the codes stored in this remote. Read all the following
steps prior to starting the auto code search as you will need to be prepared to lock-in the proper code when found.
1.Manually turn on the device you wish to control.
2. Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the button.
3. Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2).
The red indicator will blink once and then remain on.
4. Point the remote at the device and press and release the POWER button (for TV) or PLAY button (for DVD, VCR,
etc.) to start the search. The red indicator will flash (approximately every 2 seconds) as the remote searches. Note:
The remote must be pointed at the device for the duration of this search.
5. Place your finger on the #1 button so you are prepared to lock-in the code.
6. When the device shuts off or begins playing, press the #1 button to lock-in the code. The red indicator light will turn
off. Note: You have
approximately two seconds after the device shuts off or begins playing to lock-in the code.
7. Point the remote at the device and check to see if the remote operates the device as desired. If it does, no further
programming is required for that device. If it does not, return to step 2 and start the auto search.
• This process may take several minutes as the remote contains many codes.
• The SETUP button can be used during the search process to reverse the direction of the search of the remote
codes. For example, if you miss the code for your device and the remote is continuing to search (as indicated by the
blinking red light), press the SETUP button and the code search will reverse direction and return to the code.
• When using the Auto Code Search programming method, the device button corresponding to the type of device you
want to control must be selected (for example, the TV device button must be selected in step 3 if you want to control
a TV, the DVD/VCR device button for a DVD player, etc.)
be another code in the code list that performs more functions. Continue the code search as directed above until the
best code is found.
Controlling Combo Devices
Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to setup up two different Mode
buttons to control both parts of the Combo device. For example, if you have a TV/DVD Combo, you might need to set
up one code under the TV button to control the TV part AND a separate code (under any other Mode button) to
control the DVD part.
Master Volume Feature
The Master Volume Feature allows you to select a single device (TV or audio receiver) that the volume control
always controls. For example, the remote can be in TV mode while the volume buttons control the volume on your
audio receiver instead of your TV.
Enabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 4 seconds) and then release the
button.
2. Press and release desired device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) for the device you
wish to setup to control
the volume.
3. Press and release the MUTE button.
4. Press and release the VOL + button. The red indicator will blink twice and then go off. To test the feature put the
remote in another mode such as the TV mode if you programmed the audio receiver to be the Master Volume
Device. Point the remote at the audio receiver,
press and hold either the VOL + or the VOL - button. If the audio receiver volume changes then the remote is
programmed correctly. If the TV volume changes and not the audio receiver, you will have to repeat the steps above
and test again.
Disabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 2 seconds) and then release the
button.
2. Press and release the device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) which is programmed to
control the Master Volume Feature.
4. Press and release the VOL - button. The red indicator light will blink twice and go off. To make sure the Master
Volume Feature is disabled, put the remote in TV mode if you programmed the audio receiver to be the Master
Volume Device. Point the remote at the TV and
press a volume button. If the volume changes on the TV, the feature is disabled. If the volume on the audio receiver
changes, and not the TV, you will have to repeat the steps above and test again.
Reset to Factory Settings
button.
2. Press and release the MUTE button.
3. Press and release the number #0 button. The red indicator light will flash twice.
Remote does not operate your device.
• Make sure the batteries are fresh and installed correctly.
• Aim the remote directly at your device, and make sure that there are no obstructions between the remote and
device.
• Make sure you select the appropriate device on the remote you wish to control, for example, TV for TV, DVD for
DVD, etc.
• Try programming the remote with a different code. See Direct Code Entry section.
• Remote may not be compatible with your device.
Remote does not operate some features of your device.
• Sometimes a particular code might operate a few features but not all. Try programming remote with a different code
from the code list.
• Remote may not be able to operate all features of your device or button names may be different than that of your
original remotes.
Remote Code is not available for a combo device (e.g. TV/VCR, TV/DVD)
• Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to set up two different Mode buttons
to control both parts of the Combo device, For example, if you have a TV/DVD Combo, you might need to set up one
code under the TV button to control the TV part AND a separate code (under any other Mode button) to control the
DVD part.
Jan 06, 2016 | JVC Remote Control 118579 6.0 p/n:118579
I need the remote codes to make my proscan tv work with dish network. Can you supply them?
Method 2 of 3: Scan for Code
  1. 670px-program-a-dish-network-remote-step-6-version-2.jpg 1
    Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. 670px-program-a-dish-network-remote-step-7-version-2.jpg 2
    Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. 670px-program-a-dish-network-remote-step-8-version-2.jpg 3
    Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. 670px-program-a-dish-network-remote-step-9-version-2.jpg 4
    Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. 670px-program-a-dish-network-remote-step-10-version-2.jpg 5
    Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
    • Do not press the arrow buttons too quickly, or you might skip over the correct code.
    • The mode button for the device will flash rapidly 8 times when you have scanned all the codes for that device.
  6. 670px-program-a-dish-network-remote-step-11-version-2.jpg 6
    Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. 670px-program-a-dish-network-remote-step-12-version-2.jpg 7
    Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
Method 3 of 3: By Menu
    Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • The menu screen should show on your television screen:
    • 670px-program-a-dish-network-remote-step-14-version-2.jpg 2
      Select Settings. Locate and select the Remote Control button.
      • The Remote Manager screen should display on your screen:
      • 670px-program-a-dish-network-remote-step-15-version-2.jpg 3
        Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • 670px-program-a-dish-network-remote-step-16-version-2.jpg 4
        Select the Lookup Code button:
      • 670px-program-a-dish-network-remote-step-17-version-2.jpg 5
        Select the sort criteria and device brand. Then click the Next button:
        • Test the device at this point. If the remote works as expected, select the "Yes" button; otherwise, select "No" to try the next code in the list.
        • Repeat this process until a working code is found, or continue by selecting "Enter Model" to find the device code.
      • 670px-program-a-dish-network-remote-step-18-version-2.jpg 6
        Enter your model number in the search field. You can enter all, or part of the number.
        • Select the device model number from the list, then select Next. Test the device. If it works, you're good to go! If not, and you've tried all the other methods, your device is not supported with the Dish Network remote.
Sep 09, 2014 | Televison & Video
How do I get the remote codes to make dish tv remote working?
  1. Use the remote to scan your device for the proper code. If the direct-entry method does not work, or your device is not listed in the back of the manual or online, you can try this procedure to find your device's code.
  2. Turn on your remote device. Use either the device's power-on button, or use its remote control to turn it on.
  3. Press and hold the mode button for the target device. Hold the button down for about 3 seconds, then release it. It should now be flashing.
  4. Press the remote's power button. Note: use the generic power button, not the TV power button.
  5. Press the Up or Down arrow button until the device turns off. You will have to do this repeatedly to scan through all codes.
  6. Lock in the code. When your device successfully powers off, press the Pound sign (#) to store that code in the remote.
  7. Test the connection. Turn on the device with the power button, then test the other buttons such as Play, Fast Forward, etc. If those work too, you're set. If not, repeat the process again until you find a code that does.
  1. Turn on your TV. Make sure it's connected to your Dish Network, then press the MENU button.
    • Select Settings. Locate and select the Remote Control button.
      • Select the device you want to learn. From the buttons on the right, select TV, DVD, or AUX.
      • Select the Lookup Code button:
      • Select the sort criteria and device brand. Then click the Next button:
      • Enter your model number in the search field. You can enter all, or part of the number.
Need code
I HOPE THIS HELPS... YOU DIDN'T GIVE US MUCH TO GO ON....
BEST WISHES!
GE Universal remote controls - instructionsHow to Program a GE Universal Remote Control
Programming a GE/Jasco Universal Remote Control is simple, requires only a few simple steps. You need to know the code of device you are programming into the remote. See the GE remote control codes page for3 digit or 4 digit GE remotes.
How to enter codes manually:
Step 1: Turn on the device (VCR, DVD, TV, Satellite receiver etc.) you wish to program.
Step 2: Press and hold the "CODE SEARCH" or "SETUP" button on the remote until the indicator light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). For AUX, press AUX button, then the device button you are assigning to AUX. The indicator light will blink then remain lit.
Step 4: Enter the three-digit or four-digit code (depending on your GE remote model) for your device using the number buttons. After your code is entered the indicator light will turn off.
Step 5: Aim the remote at the device you want to control and press the POWER button. Your device should turn off. If your equipment does not respond to the first code listed in the documentation, repeat steps with the next code. If the device responds correctly to other functions like Volume or Program up/down, no further programming is required.
If you can't find a working code for your device or your brand is not listed try the "Code Search" method described below.
The CODE SEARCH function
Step 1: Turn on the equipment you wish to program.
Step 2: Press and hold "CODE SEARCH" or "SETUP" until the light turns on, then release.
Step 3: Press and release the button for the device you are programming (VCR, DVD, TV etc.). The indicator light will blink once, then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
Step 4: Press and release the "POWER" button until your device turns off. Wait at least two seconds between each time you press "POWER". Note that you may have to press "POWER" up to 250 times!
Step 5: When your device turns off press the "ENTER" or "SAVE" button. The indicator light will turn off. Check other functions to see if your code is correct.
The SLEEP feature
Some GE remote controls like the RM94902, RM94904 or RM94905 have a handy "sleep feature" enabling you to turn off your TV after a preprogrammed time interval of 1 to 99 minutes. To use the sleep feature follow these steps:
1: Press and hold the "SLEEP" button until the indicator light turns on.
2: Enter the time interval in minutes using the numerical keypad. (for minutes from 1 to 9 press 0 before the actual number).
3: Leave the remote aimed at the television set.
To turn off the sleep feature, press and hold "SLEEP" until the indicator light blinks or press the "POWER" button to turn off the TV.
http://www.eliztech.com/remotes/ge-howto.php
Oct 16, 2012 | Televison & Video
The screen has frozen up and has went black
Usually, the best way to remedy this is to do a hard reset on your device. To do that, follow the steps below:
  1. Hold your iPod like how you would hold an iPhone. Notice the lock button at the top edge of the device and the home button located on the front face of the device.
  2. Hold down BOTH the home and lock buttons until the screen turns itself off or, until you see a slider come down giving you the option to slide to turn off.
  3. Give a few moments for your device to turn off completely.
  4. Hold the lock button again for a few moments and your device will turn on with the apple logo on display. After a minute or two, you should see your lock screen. You can now use your iPod normally.
Mar 06, 2011 | Apple iPod touch
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
REMOTE PX-RC1 CANNOT GET CODES FOR A PHILLIPS DVD PLAYER
SEARCHING FOR YOUR CODE
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 08, 2009 | Radio Shack 15-2142 Remote Control
I dont know how to put in codes
you will have to hold the setup button untill it flashes the select the tv button , then with the tv on or if you have other device then select that device and leave the device on , then hit the power button with a pause in between untill the device turns off , then hit the mute button to lock in the device for that selection
Dec 09, 2008 | GE RM24948 Remote Control
Find a tv code for my prive soyo.
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
May 02, 2008 | Motorola Mobility DRC800 Universal Remote...
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55711 55" Rear Projection Television Logo
113 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
