Question about Akai PT50DL24 Television
The fan that is behind the bulb is making a loud noise for a few minutes and then the noise stops. We tried spraying the fan with WD40. ?? We can't seem to find a way to remove/replace this fan. Can't find any detailed pictures for this removal.
    Sergeant:
    Champion:
  • 231 Answers
Sometimes dust accumalates on fins of fans and causes rotation to deform and gets fan off balance causing noise .Also heat from lamp causes deformaties on fan and causes fan bearing to make noise.These fans can be replaced fairly easily
Posted on Jul 30, 2009
When the fan rotates it makes a loud noise. Sounds like it needs oil. Where can I put lubricating oil?
Simply disassemble where its possible and find the place of the bearings most its short right behind the propellor where the shafts come out the motor if it is hard to find for an accessible place spraying wd40 with the hose pipe on the canister behind the propellors can may be help do not use sewing machine oil because of the time being it accelerates faster dirt in the sliding bush of the shafts.
Apr 25, 2016 | Minka Lavery Minka-Aire F502-Bcw,...
When I start the car there's a loud sqeeking noise that goes away after 1 minute 2003 es 330
if it was mine, I would buy some "fan belt dressing spray" and spray my fan belts or have them adjusted. first spray them once, if sound stops a few days, have the tension adjusted. if spray does not work the first time, this is not the problem.
Apr 16, 2012 | 2004 Lexus ES 330
Our oscillating box fan is now making screechy noises. Currently I am putting it on high to get it going for a bit, then I can bring it back down to low. I figure it's just dropping some WD40 or cleaning...
hi, if you go to a car spares shop you should be able to buy a cheap accessory screwdriver kit that should have the correct adapter you need to undo the screws,
but as for using wd40 i wouldnt go that route as wd40 is an easing spray and not a lubrication, it would stop the noise for few days but then it would make it worse as the wd40 would dry up any grease or oil that is their, instead use some spray lube you can also buy this from a car spares shop or you could use something like machine oil or petrolium jelly to grease it up with this will then stop the noise and it should also work a bit better as it will be able to turn a bit easier
May 05, 2010 | Honeywell HFT-114B Super Turbo Table Fan
Bosch oven loud fan noise
JUST REPLACED BOTH FAN MOTORS ON A DOUBLE BOSCH 755. DIDNT HELP MUCH.THE FAN IS LOUD COMPARED TO OTHER BRANDS.UNLESS YOU NOTICE A DRASTIC CHANGE IN NOISE, DONT WASTE YOUR MONEY ON A NEW FAN MOTOR.ITS JUST THE WAY IT WAS MADE.
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Loud droning noise from fan.
You are correct in assuming that is a noisy fan bearing, only solution is to replace the motor complete unfotunately.
Please rate my advice.
Thanks.
May 27, 2009 | Ariston Technologies Ovens
LOUD CREAKING NOISE COMING FROM FRONT END
grease ball joints that should fix it
Mar 21, 2009 | 2002 Chrysler Sebring
Squealing NOISE possibly from fan belt
If the noise going away every time u turning off the ac it's probably your ac compressor belt.however i will suggest to take some vaseline and rub it all over the exposed parts of your drive belt.
Jun 22, 2008 | 1998 Dodge Caravan
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Fan for bulb making loud noise
This is 98% your color wheel. This coming from the TV repair shop. I have the same issue, and I'm trying to find a color wheel now. noone seems to have onein stock. I'm trying to find someoene to rebuild the one i have.
Oct 15, 2007 | RCA HD50LPW164 50" Rear Projection HDTV
Akai PT50DL24 Television Logo
557 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
