Question about NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router
Applying QoS to WNDR3300
I have a WNDR3300 netgear wireless router. I recently added a Netgear WNHDE111 wiless bridge to connect a work IP/ VPN phone (Avaya)
I am trying to use the QoS rules in the router to give this device the highest priorty. Right now the MAC address shows normal priorty. Please note the MAC address also shows 2 times in the routers list. I attribute that to the fact that both the wireless bridge and the IP phone are connecting to the router through the bridge....
When I follow the Netgear instructions to edit the priorty on the MAC address I recieve the following error:
"QoS policy for Pri_MAC_E5E465 already exist."
Any ideas how i apply QoS to the device?
My wife's downloads (required for her work) are killing my call quality
Thanks a ton
  • 2 more comments
  • texaswheeloc Jul 30, 2009
    It is connected remotely and it is the Bridge's MAC that is showing twice
    MFurrer, good comments all all valid. Let me address
    1. It is a VPN phone with a VPN load connected to CM 5.2
    2. i do not expect QoS over the VPN connection.
    The issue is my wife has to download large graphic files and at that eat the bandwidth on my connection to the internet.
    My goal is to ensure there is QoS at the edge coming in and going out at the router. it looks like this router can handle that
    Once again I don't expect QoS in the PSTN cloud, just at the edge.
  •  C. Dante
    C. Dante May 11, 2010
    Two questions:
    Is the Bridge connected to the router via cable?
    Which MAC address is showing twice? The phone's or the bridge's address?
You may stop what you are doing right now. Nothing you do will work regarding QOS and your Avaya IP phone?
Is this a hardware VPN, or a VPN remote phone? (vpn client on the phone)
Depending on what system you are connected to, an IP Office or a communication manager, there might be settings to do, but none of them are qos.
QOS is inserted on the LAN, once the packets leave the LAN and hit the open internet, there is no QOS.
You might be able to change the compression algorithm the phone is using, which might help.
Posted on Jul 30, 2009
  • Anonymous Jul 30, 2009
    I dont think it will matter, because the size of the packet trying to get out the WAN connection doesnt have the bandwidth.
    See what compression the IP phone is on. If it isnt on G.729a, try that, that might help a little.
Netgear blocks vpn
Use the web interface to administrate settings.
Netgear:
192.168.1.1
user: admin
password: password or 1234
Go to Advance > Default DMZ Server and enter the computers IP that needs VPN access. This will bypass routers NAT / Firewall, and allow all network ports access.
Oct 04, 2012 | NetGear N750 Wireless Dual Band Gigabit...
Connecting my Home Hub to Netgear to have wireless setup
3ee198b3c15f6ca7320d6cda56a651c7.png Netgear DG834G 54 Mbps Wireless ADSL Firewall Router Set-up Guide _________________________________________________________________________________________________ _________________________________
Oct 05, 2008 | NetGear DG834G Router
I recently installed a netgear wndr3300 router at my home. I went through the setup process with no problem, and everything checked out ok. But when i clicked finished, a screen popped up saying the ip...
If this is the case, the setup wizard detected an IP conflict between the router and the modem. It means that the modems IP address is in the same range as you router so it has to be changed. If the IP address of your router was changed to 10.0.0.1 , you should be able to connect to the internet. Try accessing the routers setup page by opening a browser and type 10.0.0.1 at the address bar. It will ask you for a username or password. Type admin for the username and password for password (this is the default settings). If it does not work try to remember if you already have changed the username or password. Once you are in, enable the mac clone option. Check if it works.
Apr 18, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
Ip address changing
Set your netgear router to DHCP or obtain an IP address automatically on the WAN, or public (internet) side
Jul 31, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
VPN passthrough
What are the settings that you have for your netgear router? Its going to tunnel, right? Try this solutions and see it will work.
1. Access the set-up page of the router, from a browser, type 192.168.1.1
2. Go to VPN tab and select IP SEC VPN
3. Local Security Group, set it to subnet and input the Network Address of the router (LAN IP - 192.168.1.0)
4. Remote Security Group, set it to subnet and input the Network Address of the netgear router (LAN IP, for example - 192.168.2.0)
5. Remote Secure Group, set it to IP only, WAN IP address of the netgear router
6. For Key Managemnt, just make sure that all settings are identical with the netgear router
7. Last go to Advanced Settings and make sure that group settings are identical to the netgear router
Hope it works for you
Jun 24, 2008 | Linksys RVS4000 Router
NetGear WNDR3300 - RangeMax Dual Band Wireless-N Router Logo
992 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
