Question about Cub Cadet Garden
When I start my 2180 tractor it runs rough and losses power. Could it be the timing or fuel mix. I just changed the fuel filter and one hose that was cracked.
  • 26 Answers
Sounds like the carb is dirty. if you don't want to take it off,you can let it run with fresh gas in it until it smooths out and washs out the old gas.
Posted on Jul 30, 2009
V70 volvo rough start in morning
Sounds like you may need to change your fuel filter. A dirty fuel filter will make it take a bit to make sufficient fuel pressure which will cause a rough idle or low power until it has run long enough to build up proper fuel pressure.
Mar 14, 2014 | Volvo V70 Cars & Trucks
New craftsman mower has rough idle backfires and has loss of power
It sounds like the valves are out of adjustment.
Apr 07, 2013 | Craftsman Garden
2007 chevy uplander running real rough, what could it be?
Vacuum Hoses
  • A loose or broken vacuum hose causes rough idling, and is the easiest repair of all. This is a very common problem since hoses wear out over time. Look in your engine compartment, and examine the hoses carefully for any signs of abrasion, breaking or loosening. Replace any damaged or broken sections of hose, available at most auto parts stores, and your rough idling will more than likely disappear.
Clogged Filters
  • Clogged filters are another common cause of rough idling. Inspect your air filter. If dirty, replace it. Also, a clogged fuel filter causes rough idling. It's hard to tell if a fuel filter is clogged or not, so a good rule of thumb is to change it at every general tune-up.
Electrical Components
  • Bad spark plugs, bad spark plug wires and a bad distributor cap are other common causes of rough idling. If it has been a while since you changed these components, do so. Most auto service centers can do this for you if you need technical expertise.
Timing Belt
  • A timing belt jumping a tooth is also a cause of rough idling. This throws off cam timing, setting in motion a series of events that prevent your engine from achieving proper timing. This is a more in-depth repair and, if needed, should be referred to a qualified auto mechanic.
Jun 24, 2012 | 2007 Chevrolet Uplander
I have a 1998 f150 truck with a 4.6L engine, starts fine but looses power when I put it in gear.
Sounds like a Fuel problem to me. Seems there is enough fuel to start and idle, but once the engine is placed under a load, it loses power due to a loss of fuel.
I would have the Fuel filter changed first and if the problem continues after that, I would have the fuel system tested to insure the proper pressure. The Fuel pump is in the Fuel Tank, so this can get to be a time consuming, and thus expensive operation if done at a dealership or reputable shop.
You might also check you air filter. There are only 3 things one needs to have a good running engine:
1)Proper Air Mix
2)Proper Fuel Mix
3)Proper Voltage
If any one of these are missing, it causes a problem
RPM
Jul 16, 2011 | Ford F-150 Cars & Trucks
Engine runs rough seems like it stutters but still has a good amount of horse power
A tune up may help, plugs, wires, fuel filter, air filter, if this don't take care of the problem could have a bad coil pack, you can check the coil pack, get some vacuum hose and cut 6 pieces about 3 inches long, put a piece of hose in the plug wire and the other end of hose on the coil, do all 6 wires, do one at a time so you don't get them mixed up, start engine, take a test light hook to ground and touch probe to each piece of vacuum hose, this will short out that cylinder, you should notice engine change, if no change, that coil may not be firing.
Jun 23, 2011 | 1995 Chevrolet Lumina
Was driving down son's dirt road driveway returning home at low speed in 2nd gear in my 1997 sunfire when it suddenly started running rough with no power. it will start right up and idle is rough but...
Sure sounds like a typical case of dirty/contaminated fuel....or a broken vacumn supply hose around the intake manifold area, in neutral let it idl;e and look and listen for a hissing sound, or a broken black rubber hose.
Also have the computer scanned for any possible codes.
Another thing to look at is the catalyctic converter, put a vac. gauge on the engine and see if the vac drops to almost zero...indicating a plugged cat.
Aug 07, 2010 | 1997 Pontiac Sunfire
I have a 42 inch Deck Lawn Tractor. It has been
Run out the old fuel, change the spark plug, oil, air filter. Then fill with fresh fuel...Good luck...Lee
Nov 07, 2009 | Garden
Loss of power
Sounds like either
a) you have air or water in the fuel. Drain the fuel filter container. Close it all up tight and see how you do.
b)air is getting into the system - does it take a long time to start in the morning?
c)an injector is going down. Have a garage to an injector leak-off test.
I think C sounds most likely. It is possible, if you have a very rare 1.9 Turbo edition, that you have a split turbo hose, and you are loosing thrust through the pipe. Check the rubber hoses from air filter to intercooler (if fitted) and intercooler to turbo, turbo to inlet manifold.
Jun 19, 2009 | 2006 Peugeot 505
Rough idle P0300
a faulty MAF will not cause a P0300, just a severe loss of power, look for injector, ignition and intake vacuum leaks as your causes.
Mar 20, 2009 | 2000 Chevrolet Impala
Garden Logo
106 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
