Question about Dryers
My dryer wont turn on at all, is there a internal fuse?
  • 6,784 Answers
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**(((The most common issue here will be a defective Thermal fuse)))
Posted on Jul 30, 2009
Dryer wont come on
Did the circuit breaker trip? If not You may have a bad internal fuse, motor, door switch, timer or start switch.
May 15, 2012 | Estate TGDS840JQ Gas Dryer
Frigidaire electric dryer model gleq2152es1 lights wont turn on and wont do anything
Hi ana piedranayari05, this is AP! Thank you for your post
I understand you are having trouble with your Frigidaire electric dryer not turning on. Make sure the dryer is still plugged into the outlet, and plugged in correctly. Also check to see if the house fuse is blown or circuit breaker tripped? If so, Replace fuse or re-set circuit breaker. Check to make sure that electrical circuit is not overloaded and correct. The dryer must be on a circuit by itself. Overloaded circuits can damage the dryer and possibly cause damage to home. Have a licensed electrician check to make sure it is on a circuit by itself. Additionally, the thermal limiter could have tripped or possibly an internal problem with the dryer. A thermal limiter automatically turns off the motor in the unlikely event of an overheated situation. A service technician must replace the thermal limiter after correcting the fault. If you have check the plug, fuses, and circuit breaker and still no power I would recommend contacting a local technician to diagnose and service your electric dryer.
Jan 18, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Turns on but wont get hot
Hi
The first thing to check is the fuses or breakers in your homes fuse box. If this fuse is blown, it is possible for your dryer to spin but not produce heat. If you've checked the fuses and they are not blown, the next possible cause is the heating element.
To check the heating element, move the back panel of the dryer. You'll need a volt/ohmmeter to check the element terminal. Locate the element and set the volt/ohmmeter on the RX-1 scale. Remove one lead from the element and then place one probe of the volt/ohmmeter on the terminal of the element. Place the other probe of the volt/ohmmeter on the remaining terminal of the element. Look for a continuity reading of the volt/ohmmeter of approximately 2-5 ohms. If there is no continuity reading, the heating element is defective and should be replaced.
Also clean the lint filter every time you use the dryer. Even if the lint filter is cleaned after every load, lint will still accumulate around the dryer's moving parts, the exhaust duct and vent. Each year inspect the vent pipe and vent cover operation. Disconnect the exhaust duct and remove lint from the internal exhaust pipe, the duct and the vent. Make sure the duct has no kinks, where lint and moisture can build-up.
Turn off the power; remove the front and rear panels and vacuum out the lint from around the motor and idler. Poor air flow uses more energy and can cause lint build-up in the internal ducting, leading to a fire hazard.
Please check the bellow links to get a detailed idea as to why a dryer is not heating up, you can trouble shoot your problem after going through the article therein:-
http://www.dryernotheating.com/
http://hubpages.com/hub/How-To-Replace-Your-Dryer-Heating-Element
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Please get back to us if you have further query else please accept the suggestion.
Feb 02, 2011 | Roper REX4634KQ Electric Dryer
Dryer wont start.doesn't hum when the button is pushed,circuit panel is fine.is there an internal fuse if so where and how do i get to it?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 26, 2011 | GE DVL223EBWW Electric Dryer
My basement flooded with about a foot of water. Now the dryer wont turn on. Is there an internal fuse or reset? or am I looking at a new dryer?
Make sure the motor still turns (by turning the drum) Then, with the unit unplugged, check the thermal fuses and thermostats. Also, make sure you still have power to it (that the breaker didn't trip from the water.)
Mar 14, 2010 | Maytag Centennial 7.0 Cu. Ft. Super...
Hello,my kenmore dryer wont heat. i am not sure where the fuess are? thank you mike
There are no fuses internal to the dryer, except for a thermal fuse located with the strip heating element.
Let's start with the basics, does the motor turn the drum but the unit just does not heat?
Is this a gas or electric dryer?
Please provide Make and Model number of the dryer.
Dec 18, 2009 | Kenmore Washing Machines
Maytag atlantis
Usually you will encounter a situation where a wire will burn off and in so doing, it may trip a breaker,(turn it off then back on to be certain), or if fused, it may blow a 30 amp glass fuse or 30 amp cartridge fuse. Replace both tho eliminate any doubt. If all checks ok, disconnect the dryer from the power source and go internal to find the problem. Below is a popular link to provide you with more assistance, should you need it.
http://www.repairclinic.com/0088_8_1.asp#Level1_2
Jun 08, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Fisher-paykel electric dryer
Try turning it on while holding the door switch and give the drum a spin. If it starts you will need a motor if it does nothing then look for a solenoid.
Dec 20, 2007 | Fisher DEIX2 Dryer
Washer WM-2277HW and Dryer wont turn on after power outage.
there is a fuse on the control board but it is soldered in place and cant be changed. whole board needs to be changed
Oct 19, 2007 | LG WM-2277HW Front Load Washer
Dryers Logo
75 people viewed this question
Top Dryers Experts
