SOURCE: Amana French Door Bottom Freezer
see if there is any ice caught within the ice maker itself preventing proper cycling of the ice maker. if not pop off the white cover to the ice maker(theres small **** in the cover on bottom right corner of white cover to insert a ***** driver and twist the cover will pop off. look into the center of the main plastic gear, there should be 2 "tabs" holding that gear in place . as if you were to push gear on and the tabs would keep it in place.( reason i mention that it is/was a problem with the ice makers hat the gear would break and it was very noticeable looking into the center gear).if not, theres a detailed trouble shooter for the ice maker behind the kickplate(maybe taped up under front corner under cabinet) it will tell you points to check for power and jump out if necessary
SOURCE: Maytag french door bottom freezer: Fan not working.
very easy the fan cover snaps into place and make sure you get the new motor that is metal not the plastic one they are the problem
SOURCE: I have a bottom freezer french door mode. The
remove both crisper pans and check the return are duct opennings. next check if there's a built up frost/ice on the rear wall of the frzr. is you frzr fan blowing air? if so, there's a small window inside the refrig's freshfood side back wall towards the cieling, make sure that's open.the cover should snap off. if window/damper is open, go ahead an pour hot water down the return air ducts behind the crisper pans. they look like grill slots in one or both coners
SOURCE: LG french doors, bottom freezer. Water leak from
Make sure your ic maker is empty. On the bottom of the ice maker is a small button. Watch the plastic fill tube and hold the botton in. Let the ice maker cycle anmd see if the water over shhoots rne ice maker. If it does, trim 1/8 of an inch off of the tube with a raxor knife on an angle = / this should take care of your problem.
SOURCE: Maytag french door bottom freezer keeps beeping.
the door switch might have had liquid poured on it freezing it, or the switch itself is bad, unplug fridge and re plug it in
