Question about ViewSonic Computers & Internet
Hour glass video in and out a few times then no HV or filament
Hour glass video snapped in and out a few times then lost HV and filament. Found both WH03 connector pins (heavy gauge red wires going from main PCB to CRT) burnt and solder completely blown out of their PCB pin connections (both open). Re-solder did nothing. QH06 2SC5584 checks okay with DVM. No other visible component damage or cold solder joints found. Power on clicks the relay which drops out after about 6 seconds. Green power on light eventually goes to flashing orange light. Schematic component text only 70% readable. Model No. VCDTS21692-1M
techman
  • 3130 Answers
SOURCE: At turn on,power LED goes from red to green,HV comes up,then back to red light
the T at the end of those STK means they are made in China. Start there first. Those are factory reject or aftermarket type ICs. You should always use the Sanyo IC's. Those are original replacement ICs. We all know how China has been making things these days. You can get the right IC's from here http://www.electronic-repair-kits.com/STK392-110.htm If you still have a problem after that, you will need to get a service manual and send it to me to have a look. Good Luck
Posted on Sep 26, 2007
  • 4 Answers
SOURCE: NAD C370 in protection mode
With closed eyes -replace all capacitors on protection PCB All of those caps are overheated and dry out (they lost there capacidance).Note that capacidance meter will not help you at all. Now unit will work. BUT!!! Most important!!! Check four big filter capacitors in the middle of unit!!!! If they are white (NAD 10000uF/80V) DO NOT USE UNIT AT ALL!!!! FIRE HAZARD!!!!! Contact me... Dariusz
Dariusz70@verizon.net
Posted on Feb 13, 2008
waterppk
  • 42 Answers
SOURCE: Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Posted on Mar 18, 2008
SOURCE: Panasonic TH-50PE700U red light flashing 6 times
Replaced the sc board and tv works fine again.
Posted on Jan 22, 2009
SOURCE: Viewsonic VX922 monitor no power
I had the same problem with my VX924. The two 470uFx25V was blown, and the output diode was in short circuit. I also noticed that the 33R SMD resistor (to pin 6 of SMD IC) was opened. After replaced these parts, the monitor works great.
Posted on Jun 08, 2010
My one year old microwave just stopped working. The light is on, but nothing else.
Sorry to read about your problem, I hope this helps you out.
here are some issues, but you still maybe under warranty.
  1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
  2. Bad connections (particularly to magnetron filament).
  3. Open thermal protector or thermal fuse.
  4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
  5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
  6. Damaged protective VDR from filament to chassis (not commonly used).
  7. Defective HV relay (not commonly used).
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances. Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged. A microwave radiation leakage test must be performed on the unit following any internal component repair.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 05, 2011 | Goldstar MV-1501 Microwave Oven
Micro wont heat. fix or replace? what could be the prob?
Here are some problems you can have
3 Thumbs - Helpful
Jan 05, 2011 | Kenmore 63792 Microwave Oven
It's not heating food, sounds louder than normal and smells like something possibly electrical is burning (or just getting too hot), but it looks as if it's working (lights up, tray moves inside, timer...
Here are some issues you can have
3 Thumbs - Helpful
Jan 04, 2011 | Maytag MMV5207BAW Microwave Oven
It will run but it won't heat. It also makes a funny "humming" sound and smells like burning plastic.
you may one of these issues.
3 Thumbs - Helpful
Jan 04, 2011 | Maytag MMV5156AAS Microwave Oven
Microwave activate but will not heat food all light and buttons work but will not heat up
You can many different issue's
3 Thumbs - Helpful
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave over works but no heat
you could have one of the following issues
3 Thumbs - Helpful
Jan 02, 2011 | GE Ovens
GE JVM1440 will not heat.
No heat but otherwise normal operation.
Possible causes:
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
3 Thumbs - Helpful
Jan 01, 2011 | GE JVM1440 Microwave Oven
WMH1162 not heating
Sorry to read about your problem, You have a major failure, I suggest you contact a service company. If you feel like making repairs yourself, i will give you some pointers below.
There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
Some models may have a separate high voltage fuse. If this is blown, there will be no heating but no other symptoms. However, high voltage fuses are somewhat rare on domestic ovens.
A number of failures can result in the fuse NOT blowing but still no heat:
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms.
  • Open thermal fuse - some ovens have one of these in the primary circuit. It may be in either connection to the HV transformer or elsewhere. Test for continuity. It should read as a dead short - near zero ohms.
  • Open HV capacitor - see the section: A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section:
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem.
  • Open winding in HV transformer.
  • Defective HV relay. A few models use a relay in the actual high voltage circuitry (rather than the primary) to regulate cooking power. This may have dirty or burnt contacts, a defective coil, or bad connections
  • Shorted HV diode -
  • Short or other fault in the magnetron - see the section:
  • Short in certain portions of the HV wiring.
3 Thumbs - Helpful
Dec 30, 2010 | Whirlpool Microwave Ovens
Model 721.64282 microwave/convection oven - microwave not heating and making a loud noise. convection oven works
No heat but otherwise normal operationA shorted HV diode, magnetron, or certain parts of the HV wiring would probably result in a loud hum from the HV transformer but will likely not blow the main fuse. (However, the HV fuse - not present on most domestic ovens - might blow.)
If the main power fuse is located in the primary of the high voltage transformer rather then at the line input, the clock and touchpad will work but the fuse will blow upon initiating a cook cycle. Or, if the fuse has already blown there will simply be no heating action once the cook cycle is started. There are other variations depending on whether the cooling fan, oven light, and so forth are located down stream of the fuse.
  • Bad connections - these may be almost anywhere in the microwave generator or the primary circuit of the HV transformer. A common location is at the crimp connections to the magnetron filament as they are high current and can overheat and result in no or intermittent contact. See the section: See the section: Testing the magnetron.
  • Open thermal protector - usually located on magnetron case. Test for continuity. It should read as a dead short - near zero ohms. See the section: Testing thermal protectors and thermal fuses.
  • Open HV capacitor - see the section: Testing the high voltage capacitor. A shorted HV capacitor would likely immediately blow the fuse.
  • Open HV diode - see the section: Testing the high voltage diode.
  • Open magnetron filament - This failure may also be due to loose, burnt, or deteriorated press (Fast-on) lugs for the filament connections and not an actual magnetron problem. See the section: Testing the magnetron.
  • Open winding in HV transformer. See the section: Testing the high voltage transformer.
  • Shorted HV diode - see the section: Testing the high voltage diode.
  • Short or other fault in the magnetron - see the section: Testing the magnetron.
  • Short in certain portions of the HV wiring. See the section: Testing and repairing the wiring and connections.
Depending on design, a number of other component failures could result in no heat as well including a defective relay or triac, interlock switch(s), and controller.
If you are interested in doing it yourself the following link will help : Microwave Repair Manual
(**All the above references to tests are found here)
Oct 21, 2010 | Kenmore 63663 Microwave Oven
GE profile 1800 2yrs old. Model #JVM 1870cf06. No heat,
{ MAGNETRON FAILURE }
I cut the magnetron right down the center. I can see why so many GE magnetron fail. They have a poor Filament design. The sparial spring that completes the filmanet circuit on the cathode will become brittle over time and will surely fail. I am a layman when it comes to this design. I see no GE
magnetron with this filament design lasting 10 years.
May 27, 2009 | GE JVM1440 Microwave Oven
Computers & Internet Logo
53 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
