Question about Samsung 226BW Monitor
Samsung 226BW C back light flickers. The power supply has 1 burnt part where it is apparent that a soter point arced to an adjacent one destroying a data(or power line i don't know witch) underneath the capacitors and heat sink. The other bard has some slightly melted plastic on one side of it. The plastic is melted next to the cable connection between the two boards and a spot labeled "+5V_IN". Directed i would be able to soter.
SOURCE: Samsung syncmaster 215tw monitor flickering
The capacitors BigTech referred to are C110 & C111, 820uf-25V Electrolytic, on the power supply board.
With minor soldering skills, you can replace them with Radio Shack in-store capacitors, Stock # 272-1032, 1000uf-50V Radial Lead Electrolytics for $1.59 each. Works great!
Four bucks and little bit of time saves the monitor.
Posted on Jul 08, 2009
SOURCE: Samsung 226BW 22" LCD wont turn on and flickers a blue light
Contact Samsung if you are within the three year warranty period. I did and they are repairing mine free of charge (including shipping).
Posted on Aug 18, 2009
Geekman
  • 32281 Answers
SOURCE: Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Posted on Aug 31, 2009
noone
  • 105 Answers
SOURCE: Samsung 226BW screen takes a long time to show anything
This model may have defective capacitors in the power supply. I normally replace the 2 or 4 bulging caps and normal function is restored.
Monitor Mike
Posted on Apr 21, 2010
budmrtn
  • 11361 Answers
SOURCE: Have a 226bw 3 yrs old. first started flickering
To have repaired by a reapir shop will not be worth it, DIY may be.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 14, 2010
Testimonial: "Thanks for response..."
Monitor Flicker for awhile and then settles down
The problem is in the power supply/inverter board, this is usually caused by bad capacitors that in most cases have slight bulge at the top causing it to flicker and eventually shutdown. The only option is have them replaced.
Mar 31, 2011 | Samsung 226BW Monitor
Monitor Flicker Samsung 226BW
Look for bad caps in the power supply just like all the failed SAMSUNG as shown here: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Sep 05, 2010 | Samsung 206BW Monitor
Have a 226bw 3 yrs old. first started flickering like an old movie and now is mostly black and little flickering upper right side...is it worth fixing? thanx
Jun 14, 2010 | Samsung 226BW Monitor
Samsung LCD 226BW is flickering
Yes,
The power inverter is the problem but you can repair it yourself. Check out our web site at: www.ccl-la.com We have a step by step repair guide for this model, its the same as the 214T. The repair requires replacing 5 small parts that will need to be soldered. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. If you have any questions or need service contact us at tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 07, 2009 | Samsung 226BW Monitor
My 3 yr old Samsung 226bw strobes when switched on
colinfaver, I think a visit to YOUTUBE and conduct a search for longer vid clips of "lcd monitor disassembly" and "lcd monitor repair" for monitors that suffer from the "black screen of death" syndrome and what internal electronic components fail and how to visually locate them on a "switch-mode-power-supply" and possibly replace them with new good ones and with a little luck end up with a working monitor. Your 226BW is SICK, and will probably do same if connected to a different PC with same ambient room temperature. Yes, problem with SMPS/CCFL inverter supply getting a bit tired!! If this was of help to you, please rate on fixya, and do return comment. 12fixlouie Bye for now.
Nov 17, 2009 | Samsung 226BW Monitor
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Samsung SyncMaster 226bw 22inch flickers/blinks on startup
Solution = Sledgehammer. My 226BW has been taking ages to warm up for a while and now it is a permanent dull flicker.
Aug 26, 2009 | Computers & Internet
Flicker, even when no signal cable
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 03, 2009 | Samsung 226BW Monitor
Hello cstafford35,
Your monitor has a very common problem. The internal power supply has blown a part called a capacitor. If you are comfortable working with electronics and with soldering I can talk you thru the diag/repair. If you are not ready to tackle that we also offer a repair service, about $30 plus shipping for your model. Let me know if you want to try fixing it yourself and we can go from there. The repair will require opening the monitor case and replacing from 2 - 5 parts. You can call me at 318-447-9040 if you have questions.
Buddy
Corporate Computer
Jun 17, 2009 | Samsung 226BW Monitor
Open Questions:
See all Samsung 226BW Monitor Questions
Samsung 226BW Monitor Logo
342 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
