Question about Air Tools & Compressors
We have a Sullair 100 GPQ lubricant recommendation
We have a Sullair 100 GPQ but we do not know what oil is supposed to go into the unit. Is it the 24KT Fluid or the ISO 32 Diester lubricant?
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 32 Answers
When in dought flush it out.
Posted on Feb 14, 2016
    President:
  • 1,167 Answers
Hi mate ask the manufacturers as different compressor take different oils like im a compressed air engineer and i use rcr 32 and rcr 46 but i have never had to work on a sullair as there not common in our area
Posted on Aug 08, 2009
What is the fuel/oil mix ratio for a GMC PHT22 Hedgetrimmer?
Fuel/oil ratio is a function of the quality of the oil. Pick a good oil and mix it by the oil recommendation.
I use Opti2 oil in all my 2cycle mix and it's 100:1. No problems over years of use.
Opti 2 2 Cycle Engine Lubricant Mixing Oil 34 fl oz EZ Measure Bottle...
Mar 14, 2018 | Garden
We have a sullair 100 gpq need a alternator
Condition: New Interchange Part Number: A181873 RE553516 AAK3330 AAK3359 Replaces MFG: BOSCH Other Part Number: AT220393 TY6799 F005A00023 9120060044 F005A00026 Rotation: CW Brand: Parts Player Amperage: 65 Manufacturer Part Number: PP12161N-ALT-006 , PP12161N , 12161N Voltage: 12 Design/Type: IR/EF
ebay http://www.ebay.ie/itm/New-Alternator-For-Replaces-John-Deere-RE509106-RE533516-RE553516-Se501387-/182474372388?hash=item2a7c51f524:g:6ocAAOSwax5YuI1r
it fits most models and brands.
Jun 13, 2017 | Cars & Trucks
Type of d a torque fluid used in sullair 185Q air compressor
contact sullair for this as the correct oil is essential for good performance. You may find the information on the web under sullair compressors.
Jul 21, 2013 | Cars & Trucks
Could you please let me know. 1] Can I use E10 fuel in my new RLT 30 CET 30cc trimmer that I have just purchased and am yet to start up? 2] Is 50 to 1 50mm of oil to one litre of petrol?
Hi and welcome to FixYa, I am Kelly
First off the engine is designed to operate on unleaded fuel. The manufacturer makes no statements at all about E-10 Fuel. I will tell you from experience that you can use E-10 Fuel but.... should you ever have a warranty claim make sure the entire fuel system is 100% unleaded pre-mixed fuel. Your not going to hurt the unit using E-10 fuel as long as you maintain the proper fuel-oil mixtures. If anything a splash more of 2 stroke oil as in 22 mm / liter vs 20 mm. Or (+) 8 mm per gal.
Manufacturers statemenrts and recommended fuel mixtures below:
Thanks for choosing FixYa,
Kelly
n This product is powered by a 2-stroke engine and
requires pre-mixed petrol and 2-stroke lubricant . Premix
unleaded petrol and 2-stroke engine lubricant in
a clean container approved for petrol.
n This engine is certified to operate on unleaded petrol
intended for automotive use with an octane rating
of 87 ([R + M] / 2) or higher.
1 Litre + 2 0 ml =
2 Litres + 4 0 ml =
3 Litres + 60 ml = 50:1 (2%)
4 Litres + 80 ml =
5 Litres + 100 ml =
The full operators manual is here:
http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Feb 27, 2011 | Ryobi 15" Electric Factory Reconditioned...
I want to know what is the optimum km range for changing engine oil in Honda Unicorn.
Optimum km range for changing oil in any bike should be 1000km or 6 months which ever comes first. The oil in a motor is designed not only for lubrication but also to keep the engine clean, if you leave oil in a motor for too long than you are lubricating your motor with dirty oil, oil also loses its viscosity to lubricate and that is why there is a time span. Both oil companies along with manufacturers have increased there oil change (servicing) intervals to some silly kilometre and time spams, sometimes common sense prevails. Use a good quality oil, no need to buy the top of the range and maintain your bike
Feb 19, 2011 | 2005 Honda Unicorn
I have a gen power gx400i generator 4.0kvaor 3.0kw, 4stoke single cylinder air cooled.I'm not sure what type of oil is needed?
Hi and welcome to FixYa, I am Kelly. Oil changes are supposed to be every 100 hours. You should use SAE 30 WT (non detergent) oil for at least 3 oil changes / 300 hours then 1 cycle of HD-30 WT oil as it does a bang up job of cleaning things out of the crank case and prevention of the oil rings from sticking on the piston skirt. I have made this recommendation for at least 30 years and never had to rebuild a home owner or RV type engine in a unit where it was known the owner did this cycle of oil changes in a generator. (Vavle work yes.. engine bearing and piston rings no!) .. The brand does NOT matter as long as it is SAE 30 WT oil. Lubricants can not get the SAE rating if they do not meet the standards. Just do NOT use a synthetic oil in it.
Kelly
Nov 29, 2010 | Coleman Powermate Premium Plus 6250W...
Sullair 185 screw compressor
The sullair 185 has a low oil pressure override button that you have to hold in while starting. after the oil pressure builds up(takes about ten seconds) you can release the button and the machine should continue to run.
Feb 19, 2010 | Chicago Pneumatic 1/4" Air Screwdriver
Where to oil a Fellowes Powershred 320 CC paper
I continued to search via Google until I found the manual for this shredder, which I then printed out and read how to lubricate the shredder.
Jan 26, 2010 | Fellowes Office Equipment & Supplies
My grandfather opened up the motor compartment on his Kitchenaid stand mixer and about 1/4 cup of oil came out. Does anyone know if there is supposed to be that much...and do you know what kind of oil is...
Yup, gotta have lubricant. That oil started out as grease. It is food grade grease and most appliance psrts places have it.The motor itself should be oil free. The grease is for the gears.:)
Oct 28, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I'm getting a loud knocking/clicking noise @ about 2-3 rpm in my 2007 sx4, I use 5-30 synthetic and have recently changed it to see if it would help, but the noise is still there. The shop forman said he...
I don't recommend using synthetic oil on any vehicle and some manufacture does not even recommend synthetic due to it viscosity. they are excellent oil but have seen and heard it has torned up allot of oil pump and some engine. The only benefits you get from synthetic is that the oil tend to last a bit longer in extreme heat and does not break down as quick with the original oil and you don't have to change the oil often. synthetic is very thin oil does the job, during start up i don't think synthetic give the engine that protection it needed when it come to lubrication; again that my personal belief. They now offer 50/50 oil instead running 100% synthetic. If your car still under factory warranty, I would take it to them and have them look at the vehicle. keep in mind, if the car in still under full factory warranty and you have non Suzuki mechanic touch the car it will void the warranty completely.
Oct 21, 2009 | 2007 Suzuki SX4
Air Tools & Compressors Logo
332 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
