Question about Sony Cyber-shot® DSC-W120 Digital Camera
Zoom does not work. The screen says to turn power on and off
We traded the camera in. Thank you.
Posted on Aug 01, 2009
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
I see 1/4 on my iphone
Try tapping the screen with 3 fingers to un-zoom. You can turn this off in Settings: General -> Accessibility -> Zoom
Jan 12, 2010 | Apple iPhone 3G
Zoom error comes up on LCD screen when trying to take picture....
I had this error and did two things to fix it and am not really sure which worked, or it may have been both:
1) Charge your batteries or replace with high power (2700) type
2)Is there a bit of dirt stuck between the zoom bit and the body?
With my S1000fd, if I press the on/off while holding the zoom bit so it cannot come out fully, I get the "zoom error" message.
Hope this helps.
Mar 28, 2009 | Fuji FinePix S1000FD Digital Camera
S5000 fujifilm
Was probably caused by the zoom carriage locking on power out due to batteries running low. Turn off camera, tap barrel with solid but non-metallic object and turn on. Did this two times and it worked for me on second.
Oct 16, 2008 | Fuji FinePix S5000 Digital Camera
Camera doesn't turn on and zoom screen got stuck because camera shut off!
MY CAMERA IS HAVING TROUBLE TURNING ON. THE OTHER DAY I TOOK A PICTURE AND IT SHUT OFF IN THE MIDDLE OF IT WITH THE ZOOM LENS OUT. NOW WHEN I PRESS POWER IT SAYS RETRY POWER ON OR IT WONT DO ANYTHING AT ALL. THE BATTERY IS CHARGED ALSO BUT NOW I CANT USE IT AT ALL
HELP!!!!
WHAT DO I DO!!!
STACY
Jul 21, 2008 | Casio Exilim EX-S500 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Broken Zoom on Fuji Finepix F470
Try turning the power on and gently pulling the lens outward as it powers up. This may force the gears to re-align themselves. Use "fingertip" pressure only. Don't force it excessively. Also try turning on, and then applying slight pressure to the front of the lens while you power it off. You can also try rotating the lens barrel segments while it powers up or shuts off. Sometimes either can get the lens back on track.
Jan 20, 2008 | Fuji FinePix F470 Digital Camera
Zoom extended but no power
You are going to have to send that in to be fixed. Even if you call tech support they would tell you that.
Nov 12, 2006 | Casio Exilim EX-Z40 Digital Camera
Sony Cyber-shot® DSC-W120 Digital Camera Logo
83 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
