Computer freezes when I start it
When I start the computer a message comes up "a problem with the hard drive has been detected. consult the troubleshooting section of your user's manual." "press enter to continue" hit enter then "press F4 to run setup" when you hit F4 nothing happens.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Please make sure the boot device is correct from BIOS.
If correct please boot your system from Windows XP bootable CD and choose recovery option in Command Mode.
run the command
chkdsk /f C:
Check the result and let me know if any error comes.
Posted on Jul 30, 2009
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
Hard disk not found message coming while installing windows server 2003 on HP Proliant ML150 G5 server system.pls help me
Save any critical or important files. Even if this is an secondary hard drive installation.
Turn off the power and unplug the PC from the outlet. Also, unplug all external connections to the Windows PC. Be sure to touch something metal to ground the user. Static electrical shocks can damage a PC.
Open the PC housing and determine the placement of the hard drive. Generally computers come with a latch that, when pressed, opens the housing. Make certain the space necessary for the hard drive is available. Usually the drive bays are in the front of the PC near the CD or DVD drives.
Make sure the IDE jumpers are set correctly. If the hard drive is the primary drive then set the jumpers to "Master" mode. If the hard drive is the secondary drive then set the jumpers to "Slave" mode. Please consult the hard drive's manual for the proper jumper setting for each mode. Another possibility--if there are two hard drive, set both drives to "Cable select" mode and the Windows PC will choose which one to make "Master" and "Slave."
5
Mount the hard drive in the available internal slot. The drive is sometimes mounted with four screws to the drive bay. Some internal drives have a rail that slides into the open bay. Look at the other devices to determine which mounting option is available in the specific computer.
6
Connect the hard drive cables to the Windows PC. Connect the power supply connector to the available cable. Next, connect the data cable to the available connector. The internal data cable usually has a red stripe to make identification easier.
7
Close the housing and reconnect the external power supply. Plug the external cables back into the computer and reconnect to the power supply.
8
Configure the BIOS. The BIOS (Basic Input/Output System) is accessible during computer start-up. To access the BIOS consult the computer manual to find out with which key press during start-up. Most often, the key is F8. Once in the BIOS change the hard drive setting to "Auto detect." When finished, exit the BIOS and allow the start-up to continue.
9
Format and partition the Windows PC hard drive. Select "Start" from the operating system menu. Choose "Control panel" from the start menu. Next click on "Administrative tools". From the administrative tools menu choose the "Computer management" icon and finally "Disk management." Choose the new hard drive and right click. Select "New partition" from the right click menu. Follow the on-screen option to partition and format the drive the drive.
10
Restart the computer and check the hard drive to ensure it is operating properly.
Feb 23, 2011 | HP ProLiant ML150 G5 Server - 1 x Xeon...
When my computer starts it goes to a black screen and says "no bootable device jnsert boot disk and press any key" what can i do
Normal 0
This error message - "No bootable device. Insert boot disk and press any key" means -
The PC cannot see a boot file/disk on either the hard disk or floppy drive.
Check the floppy drive and remove and floppy disk.
If there was no disk in the floppy drive then it is a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect the hard drive, then the hard drive is probably faulty.
A further check on the hard drive, remove the hard drive and connect it to an USB hard drive adapter and connect it to a working computer's USB port, if this computer does not detect it as an external storage device then the hard drive is faulty.
To get the computer working again, install a new hard drive in your computer and then install Windows on the new hard drive plus the computer's device drivers and your programs.
Oct 02, 2010 | Computers & Internet
For my pc everytime i turn it on it works fine but when the window loader bar comes, my computer starts to load slowly then before then when its done loading everything freezes and i get this blue screen...
you might be real low in memory on your hard drive if you hear your power sulle py fan running all the time it most like is full of dust and over heating plus your cpu fan will be dirty as well
Jun 02, 2017 | Cube Apps ComputerTest
Asus P320 does not detected on computer. It was since last month I think.. And I have another problem, which may cause the above problem The other problem is that my Asus P320 seems to ''freeze'' its...
backup all your data and then hard reset.
To reset your phone
1. Tap Start > Settings > System tab > Default Settings.
2. Key in "1234" to confirm that you want to restore default settings and press OK.
3. Tap OK.
The phone will restart automatically after it is reset.
Mar 25, 2010 | Computers & Internet
MY GATEWAY PROFILE 4 ISSUES A PROBLEM WITH THE HARD DRIVE.
Bad news. Your hard drive has had a SMART failure and subsequently crashed. If your data was important, I would get the computer to a skilled professional as soon as possible. Ideally, you can get them to make an image of your drive. That will get you back to right before the crash. If they can't do that, there are data recovery places like gillware.com that can help you out for a flat fee.
Jan 25, 2009 | Gateway Profile 4M PC Desktop
It takes @least 30 minutes to boot
It sounds like your computer is not recognising the hard drive. Go into the bios (keep pressing the delete key as your computer starts up ) and find 'hard drive auto select' and press enter to see if your computer can recognise the hard drive. Even if this works it sounds like your hard drive is on the way out.
1/ Make sure no floppy or CD in drives
2/ Check Hard Drive cable connections, both ends
3/ Go into BIOS and check drive is recognised in there
Nov 19, 2008 | IBM NetVista PC Desktop
Hard drive message
Probably the hard-drive has gone bad.. First try a complete re-install of windows (you will lose all saved data on the hard-drive, so if you can, back up all important files first)..
If that doesn't work, you need to purchase a new hard-drive
Apr 03, 2008 | Gateway GT4022 PC Desktop
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
