If you wipe over the control panel while the hob is switched on, settings may be changed. To avoid this, the hob has a function you can use to lock the control panel for cleaning. To activate: Remove the twist knob. An audible signal sounds. The ? indicator and the hob settings flash. The control panel is locked for 10 minutes. You can now wipe over the surface of the control panel without altering the settings.
To deactivate: Put the twist knob back on within 10 minutes. The control panel is unlocked. To end the function early, put the twist knob back on before the 10 minutes have elapsed.
I expect you have found the solution by now since this post is so old - but for any other that are searching, just push the child lock knob down and turn the knob and it should pop back up, turning the gas back on.
Go to the Howdens Joinery Company website and find your local depot. Once there, inquire about Lamona Ceramic Hob parts. Sorry, I'm in the USA and really can't be of much help. Good luck.
Hi. Yes you can buy a new glass. Most of the come with frame top now. If you get me the model # I can look this up for you and get you an idea on cost.
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
use mactches for ur gas burner if the ignition not really work.put all gas in off position b4 cleaning by using a vacium in the place of the control knob,turn off the power b4 try to clean,tnx
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
