Question about Raypak 130,000 BTU Propane Gas Pool H...
Our Raypak heater model 402WHG won't fire up because our pool man says something has chewed through one of the wires. Can we fix it ourselves?
    Scholar:
  • 91 Answers
Your pool man should have fixed it when he was there. It is a simple enough of a fix. No idea why he didnt just do it instead of just telling you about it, possibly to try and get another service call.
If you are mechanically inclined, it is a simple fix...depending on the location of the broken wire.
Posted on Aug 22, 2009
Raypak pool heater shows 'sensor failure' and also 'sensor open' - what does this require/ thanks
I would check the sensor wiring on side of unit where the inlet and return manifold is - chances are little critters chewed the wires to the sensors. may need to replace the wires if they are too mangled, or can try to splice
Jul 31, 2017 | Raypak Pool & Spa
What caused our 156 raypak pool heater to catch fire within 2 minutes of installation
wrong heater if it is a natural gas unit orfices too big and wrong regulator if natural gas heater check gas pressure
Jun 15, 2014 | Raypak 130,000 BTU Propane Gas Pool...
RayPac Pool heater won't light
check gas pressure too low it overheated replace fusible link on bottom after gas is fixed then clean heat exchange of soot
Apr 20, 2012 | Raypak 130,000 BTU Natural Gas Pool...
Raypak 2100 just get SPK then LO codes. won't ignite
if wired 120 volt check wiring and check gas pressure see if lines have cobwebs
Jan 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Gvc code heater won't fire
gas valve closed check gas pressure
May 28, 2011 | Raypak RP2100 DIGITAL POOL HEATER R265
Versa model#055b The piolet light is on but the burner will not fire. I can get it to fire by jumping the a&b terminals,
You need to start by hooking to one terminal and folowing the wire to each componenent on the line the problem will be with the one that fires the heater. You will need to look further once you find the component. For example if you find the pressure switch to be the problem it may be a dirty basket or a rusted water header or just a bad switch. So each component will only be a symptom. Good luck.
Dec 30, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Raypak 130,000 BTU    Propane Gas Pool H... Logo
131 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
Paul Carew
Jim Goldsmith
Jim Goldsmith
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
