The problem could be the dryer thermal fuse. It is usually located on the blower housing. If the dryer overheats, the thermal fuse blows to cut off power to the dryer. If the thermal fuse has blown, then generally the dryer won't start. If your dryer drum rotates, but does not heat, then the problem could be something else.
If it is the thermal fuse, it cannot be reset-if the fuse has blown, it needs to be replaced.
If it is the fuse ... it is also important to figure out WHY it blew ... or else the same problem could show up. Sometimes the thermal fuse blow due to a clogged vent. That should be checked.
Helpful?
Good luck with your troubleshooting
SOURCE: replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
SOURCE: how to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
SOURCE: Need to replace the heating element in stackable Kenmore model 417.98702891
hi thanks for the question just underneath the dryer on the front theres a panel remove this panel the element is on the right thanks for the question the appliance doc
SOURCE: kenmore gas dryer does not heat.heating element
Your gas dryer uses a pilot-less burner assembly that has an electric igniter. It is designed this way to prevent free-flowing gas from filling up the appliance cabinet without ignition. Such a condition could cause an explosion. The way the ignition system in most of today’s appliances work is like this:
1. Press the start button.
2. The igniter on the burner assembly begins to glow.
3. Once the igniter reaches the required current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
If you are having problems with ignition, it may be something as simple as a bad igniter. Just because an igniter glows, does not necessarily mean it is good. They do become weak with age and if they do not draw the required current potential, they will not allow the gas safety valve to open. There are two basic types of igniters:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
Your igniter appears to be the Norton type. The part number is 279311 and can be purchased at pcappliancerepair.com for about $22. Instructions should be included with the parts kit.
NOTE: If the igniter connector plug does not match the one you have, there are instructions that explain how to cut and splice the connections using a set of ceramic wire lugs included with the kit. Do not use standard wire lugs as they will melt due to heat.
CAUTION: Make sure you unplug the dryer and turn off the gas source prior to servicing.
If you have questions, or require additional assistance, please post back so I may be able to assist you better. I hope you find this information helpful.
PS Use model number 110.76912690 for your search criteria.
SOURCE: kenmore dryer will not git hot HEATING ELEMENTS is
Hello, Ok if you have checked the heater, hi-limit, thermal fuse and thermostat and they are all good your problem is going to be with the centrifugal switch. This is built into the motor. To check this pull the wire harness off the motor and where you see the 2 big wires going into the plug make a jumper wire with 2 male spades and some wire. Jump this wires and then run a cycle for a few seconds. if the heater comes on you have found your problem. This will require you replace the motor. Hope this helps. Mike
