Question about Cell Phones
My screen start to dim down when i slide it up and now it frozzing when turn it on it on but the panteh sign get caught in the midde so it kinda stuck wat should i do
Why does my cell phone have a blank screen?
I have a Samsung Galaxy S5 I was using in McDonalds on their free wi-fi. I slide down the notifications to check some download and accidentally swipped the screen dimmer all the way to the bottom without realizing it. Instant black screen.
I thought maybe the battery had gone dead. So I hooked it up to the charger when I got home. It was kinda dark where I plugged it and I noticed the screen was not black but very dim. Then I realized what had happened.
I don't know if your phone has a similar dimmer slider in the notification slide-down but if it does this might be what happened to yours. The key is to look at your phone in a dark place.
Mar 08, 2015 | Boost Mobile LG Realm No-Contract Cell...
My acer aspire 9300 overheated and donno what to do
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Nov 21, 2012 | Acer Aspire 9300-5005 Notebook
I'd like to brighten up the picture kinda dim samsung hl-s5686w what can i do?
Turn up contrast to 95 and turn down brightness accordingly. If it is oddly dim, you may have a problem with the backlight.
Jan 28, 2011 | Samsung HL-S5686W 56" HDTV
The picture is almost hazy and is kinda dim. picture not bright??
have you tried to take off the front screen and clean the lens and mirrors yet? if this is a philips 9or a magnavox you will most likily need to change the fluid inside the picure tubes
May 08, 2010 | Televison & Video
My cursor is stuck in the midde of the screen and want move, I have to use the up and down keys and it will work some of the time
Turn off, Unplug mouse, Turn on comp, Let it boot, and replug it in. It should re-register and you should be fine, if not, turn off, plug in the mouse and try again.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | Microsoft Comfort Optical Mouse 3000...
Screen dim HP pavilion dv1000
The lid actuator switch may not be working correctly. It's a small switch above the keyboard and led's on either the right or left side. Try pressing it 2 or 3 times to see if the display starts working correctly again. If so, it will need to be replaced.
If that doesn't work, you can also turn it on with the ac adapter plugged in. After it boots, press the power button and hold it in until it shuts off and then turn it on again and see if the display has returned to normal.
If neither of these options work, your laptop may need to have the backlight replaced.
Aug 13, 2009 | HP Pavilion dv1000 Notebook
Lights get dim when you let down a window.
Is it any window or one certain window. I would still get my battery and charging system checked anyway. If it is one certain window you might what to have it checked due to it pulling alot more power than the others. Blinking or kinda lightly flashing headlights is a sign of an alternator problem. I would also check my battery connections.
Dec 14, 2008 | 2004 Chevrolet Tahoe
Dim screen
A New Backlight, or new bulbs for your backlight..
Jun 09, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Phone fell white screen
you need to have the flexcable replaced in the mobile....take it to a mobile store and have them replace it for you.
Feb 05, 2008 | Samsung SCH-u740 Cellular Phone
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
