Question about Graco Quattro Tour Travel System
How do you fold it?! - Graco Quattro Tour Travel System
  • 14 Answers
On our Graco, there are plastic pieces on each side of the handle, just below where the rubber ends. We stand behind the stroller and pull up on these 2 plastic pieces (They encircle the metal bars, so you're pulling them up the bars, about an inch.) The stroller will then begin to collapse. I hope this helps!
Posted on Sep 29, 2009
07 corvette top will retract but deck lid makes no effort to close, then top will not go back up. Need to release pressure in block lift top up about 1/4 of way then top will go back up
Manually Moving the Folding Top from the Down Position
Important: Allow the system a minimum of four minutes to bleed down pressure after the last cycle.
Manually release the folding top cover latch using the emergency release cable.
Raise the folding top stowage cover.
Manually raise the folding top, holding the 5 bow up.
Manually lower and latch the folding top stowage cover.
Manually unfold the top and latch per normal procedure.
Manually Moving the Folding Top from the Up Position
Manually release header latch per normal operation.
Manually lift front of roof off of the header and raise the #5 bow at the same time.
Manually release the Folding Top Cover latch using the emergency release cable.
Fold the roof down into the well.
Manually close and latch the folding top stowage cover.
Power Folding Top System Components
The power folding top system consists of the following components:
• Folding top control (FTC) module
• Body control module (BCM)
• Folding top control switch
• Serial data communication
• Folding top cover latch actuator
• Folding top cover pull down actuator
• Folding top pump motor with valve manifold
• Position switches and limit switches:
- Pin receiver switch
- Luggage barrier switch
- Folding top cover open switch
- Top open switch
- Top closed switch
- 5 bow raised switch
- 5 bow lowered switch
• Tonneau release relay
• TONNEAU PULL DOWN ACTUATOR Fuse 20 A
• TONNEAU RELEASE Fuse 10 A
• BATT 2 Fuse 40 A
• REAR FOG/ALDL TOP SW Fuse 10 A
• Folding top mechanical components:
- Folding top
- Folding top cover
- Folding top valve 1
- Folding top valve 2
- Folding top valve 3
- Hydraulic lines and cylinders
Folding Top Cover Latch Actuator
The power folding top system includes a folding top cover that is powered open and close by a hydraulic system that is controlled by the FTC module. A power unlatch motor is used to unlatch the folding top cover before the folding top control (FTC) module powers the top cover open. The folding top cover unlatching is requested by the FTC module via class 2 message, but is executed by the body control module (BCM). When requested, the BCM applies battery voltage through the folding top cover release relay control circuit to the tonneau release relay. The relay is energized and battery voltage is applied through the folding top cover release control circuit to the latch actuator. The actuator is energized and the latch releases the folding top cover.
The electronics on this are very complex ,
System Operation
Before any movement of the power folding top is allowed, the folding top control (FTC) module must be aware of the following conditions:
• Unlatch the header. The FTC module reads the pin receiver switch is Inactive.
• The windows must be normalized. Refer to Power Window Reinitialization.
• The ignition must be placed in Accessory or RUN.
• The transmission must be placed in PARK, or with manual transmission, the park brake must be applied.
• Trunk status must not be ajar.
• The luggage barrier must be in place.
• The pump motor temperature must be within the operating range.
After the last cycle of power folding top operation, allow the hydraulic system a minimum of 4 minutes to bleed down before attempting manual operation of the top.
Your best bet take and have it checked for DTC'S - diagnostic trouble codes .
DTC B3666 Rear Tonneau Position Error
DTC B3667 Tonneau Release Circuit
DTC B1011
DTC B1291
DTC B1420
DTC B3602
DTC B3666
DTC B3667
DTC B3670
DTC B3971
Jan 23, 2017 | 2007 Chevrolet Corvette Convertible
What are the different types of folds that a paper folding machine can do?
There a few different types of folds that a paper folder can do. All the different kinds of folds can be found on this site. Before you get excited about all the different folding options that are available you want to make sure that your folding machine is capable of doing those folds.
Sep 24, 2013 | Office Equipment & Supplies
What is a paper folding machine?
This is a machine that folds papers or letters instead of you folding them all by hand. It can fold statements, invoices, brochures, etc. It's really useful for businesses. It can fold about 1800-18000 papers in a single hour.
Jan 17, 2013 | Office Equipment & Supplies
What are bi-fold doors? Can I use them as a room divider?
Bi-fold doors are often used when space in a room is limited and there is no room to open the door outwards. Bi-fold doors fold inwards and can visually be a real feature in the room.
Sep 12, 2012 | Furniture
What is a folding table?
A folding table is a two or four legged table that can be flattened via hinges on each of the legs. Folding tables are very convenience because they tend to be very light weight and can save space.
May 29, 2012 | Furniture
I'm looking for a folding changing table
There are 2 typs of folding tables: the ones that can be folded against the wall and the ones made mostly from fabric and are folded in the middle. There are so many types of them. You can try theses 2 links:
Folded against the wall (http://interiorforhome.com/baby-table-for-efficient-and-ergonomic.html) Regularly folded: (http://www.babytables.net/fortifying-style-with-folding-baby-changing-tables.html
May 29, 2012 | Baby Gear
What is a Folding Bicycle?
A folding bicycle is a bicycle that folds for convenient storage and portability. The perfect folding bike would be one that rides as well as a quality full-size bike, folds in seconds, weighs less than 10 kg (22 lb), and folds small enough to fit under a bus or train seat.
Dec 16, 2010 | Cycling
Once I've folded my phil & ted vibe (in single mode) the locking clips won't fold into place (I've used as much force as I dare -- worried I might break the clips if I try any harder). This makes it...
When folding the Vibe some important things to remember are that the handlebar must be in the most upright position (perpendicular to the ground), nothing can be below the rear axle level (ie. lift the basket up above this) and the front single wheel should have the side with the attachment bar on the outside.
The fold locks will not engage if everything is not in the correct position. If everything is in the correct position the fold locks will easily engage/disengage. If everything is NOT in the correct position the fold locks will not engage and should not be forced.
Folding:
  1. Put handle bar in upright position.
  2. Undo the side lock clips. Then you lift the red lever on the side to start the fold. Fold so that the pram front wheel and handle come together.
  3. As the pram folds ensure basket is above rear axle and the front wheel has the attachment bar on the outside.
  4. When the pram is fully folded you can fold the side lock clips back in place.
Nov 12, 2009 | Regal Lager Phil & Teds Vibe Jogger
Wing mirrors on 06 plate Golf TDi
Has it ocurred to you that your wing mirrors are not the electrically folding type, most are not. The switch on the drivers arm rest for adjusting the mirrrors will have a separate position for folding if yours fold. The resistance to fold by hand is very stiff as you have to overcome the spring tension, even when folded by hand they do not fold as flat as you might think.
I purchased a 2006 Golf 5 GT Tdi last year it had £5000 worth of factory fitted options but did not have electrically folding door mirrors - hope this helps.
May 14, 2009 | 2006 Volkswagen Golf
Graco Quattro Tour Travel System Logo
132 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Colin Stickland
Colin Stickland
john milligan
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
