Question about Sanyo PLC-XP57L LCD Projector
Can't get the lamp light to turn off on my sanyo xp57 projector. replaced the lamp and the lamp warning light won't shut off.
    Problem Solver:
  • 5 Answers
Go into the menu and look for the settings icon. Under the setting icon you should see a lamp counter reset button. Select that and the lamp replacement light will go out.
Posted on Aug 01, 2009
How do i reset sanyo pro xtrax multiverse projector "replace lamp" error message
1,Turn the projector on,press the Menu botton
2,Press the Left ,Right,Up or Down to find the "lamp usage" and the reset option.
3,select "Lamp replacement counter Reset ?"
4,select "Yes"
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 31, 2014 | Sanyo PLC-XE20 (Chassis XE2000)...
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
We have a Sanyo XP57 projector. Occasionally (not every time), the unit boots up and the lamp comes on for a few seconds before turning off and all the lights on top of the unit flash. Turning on and off...
It's possible that your lamp could be coming to the end of it's life. Do you have a replacement lamp to try. One more thing to check, how is the air circulation around the projector? Is the filter dirty? These are things to check.
Good Luck
Sep 28, 2009 | Sanyo PLC-XP57L LCD Projector
Projector will not power up, confirmed 120vac to unit is good
this particular model will not come on if the bulb is burnt out. check the bulb. most common problem.
David
May 25, 2009 | Sanyo PLC-XP57 LCD Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo plc-xu35
Sounds like a simple problem to fix but don't ask here unless you plan on signing up...take your projector to a "real" professional who'll actually speak to you.
Sep 12, 2007 | Sanyo PLC XU35 Multimedia Projector
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
MULTIMEDIA PROJECTOR
have you ever seen the lamp come on? has the unit been used for a prolonged period with lamp on?
May 24, 2007 | Sanyo PLC XU35 Multimedia Projector
When u switch it on a timer comes on for 30 seconds then the projector turns off can any one help please
Had the exact same problem, after my projector was powered off upruptly.
Turnedout all I had to do was push down slightly on the tempreturesensor/fuse (is opens the power circut if the projector gets too hot,and thus doesnt allow any current)
Here is the full repair/service schematic for the projector. It should help you locate the sensor.
Good luck
http://yama.co.za/forum/index.php?topic=146.0
Apr 13, 2007 | Sanyo PLC XU30 Multimedia Projector
Sanyo PLC-XP57L LCD Projector Logo
354 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
