Question about Whirlpool ED0GTQXMQ Side by Side Refrigerator
Whirlpool side by side does not cool at all
5yr and 8 mos old...stopped cooling, Compressor is very hot, I can hear a clicking noise and feel slight vibration in compressor that lasts about 20 seconds, then nothing for a couple of minutes, followed by click and vibrate...cycle heeps repeating
    Problem Solver:
  • 15 Answers
Simple Fix. That's cost around $40. You need to replace your relay/overload. Its mounted on the compressor. It should have a black box over it. Take it off then pull the part off the compressor and replace it with a new one.
Posted on Jul 30, 2009
Amana refrigerator bottom freeze is not cooling; about 8 years old; the cooling switch was replaced and still does not cool
Kim pull refrigerator away from wall and unplug power. Remove lower panel that cover compressor and condenser fan and condenser coils. Don't wait too long but feel the top of compressor and tell me if cool, warm or too hot to hold had there. Let me know those results as I gather up the possible problems that could be related. Did you by chance check the defrost timer by turning timer through opening below and behind the Control panel=> ARB2217CSR Control Panel Did you say you changed a switch or thermostat here? See the defrost timer in photo at location 12? Try turning clockwise slowly until compressor starts or stops what ever may be happening. If stuck in defrost the timer part number=> 67001036 Defrost Timer It is possible that is the only problem but I will wait until I hear from you on turning the defrost Timer and feeling the top of compressor. If this post is helpful please rate, Thank You, John Tripp/AKA Sea Breeze
Nov 22, 2011 | Amana ARB2217CSR Bottom Freezer...
I have a Whirlpool GC5SHEXNS00 side-by-side refrigerator that has stopped cooling. For quite some time the center column was hot to the touch, but it maintained the ability to cool. Now it no longer cools...
If the center wall was hot then your defrost heater was stuck on, now with no cooling it could be you burnt out the compressor or the main board could be fried. Not good either way, it might be time for a new one. Sorry
Nov 09, 2010 | Whirlpool GC5SHEXN Side by Side...
Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Apr 03, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge working but not cooling.
The white component you see , is the problem . That is the overload/relay . These short due to power surges , dirty coils in the front bottom of refrig , or just by age . They short , to save the compressor , when one of these happens . The part number you need is # 8201786 . This part just prys off (maybe one wire clip ) , easily replaceable with instructions included with the part .
Sep 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool GS6SHAXLB03 Refrigerator or freezer do not cool.
This sounds like it's out of freon. Not just low but out. That clicking noise is a thermal overload shutting down the compressor. If you continue let it just click away it will burn this overload out and the compressor will have to be replaced. If the refrigerator just started doing this suddenly it could be that the compressor is locked up. If it has external capacitors either the start or run capacitor could be bad. If the capacitors are good then you could try a hard start kit to try to unlock the compressor.
Jun 30, 2009 | Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side...
Whirlpool side by side, blowing hot air on both sides
First, you must determine if the compressor is running. The compressor is located at the bottom of the unit in the rear. Feel for motor heat and slight vibration. If it is cool then the problem may be an inexpensive start relay. If the compressor is very hot, the start relay could also be the problem or the motor has seized. Find the wiring diagram in the rear of the unit to replace this relay which should be availible at your local refrigeration supplie house.
Ray
Jan 05, 2009 | Whirlpool Refrigerators
Refridgerator/Freezer stopped cooling
if the compressor was very hot to the touch, suspect you have a compressor fault
Oct 02, 2008 | Refrigerators
COMPRESSOR STOPPED WORKING
if the compressor isn't running and is hot or you hear it clicking noise then replace the overload rely on the compressor its the little whit box on the side of the compressor shake it after taking it off and if it rattles and black stuff falls out the thermo disc is bad
Dec 31, 2007 | Amana ASD2626H Side by Side Refrigerator
Whirlpool ED0GTQXMQ Side by Side Refrigerator Logo
328 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
