Question about Magic Chef (CSD2610KRW) Top Freezer Refrigerator
Ice maker Our ice maker is making hollow ice. Our fridge is around 10 or 11 years old. Please help us in solving this problem.
  • drill Nov 28, 2007
    Dear Drill,
    Thanks for you info. But the problem is still there. We looked for a filter and could not find one. The copper line had a crease in it, so we fixed that thinking that might help, it did not. We are still getting hollow ice. My Magic Chef model number is RB21KA4AF. The model number on the ice maker is IM`s 106-626640. I would appreciate any info you could give to us.Thank you.
  • Lisa Wiebalk Jul 20, 2008
    W have just insalled a new icemaker in our side by side "Whirlpool and it's making hollow ice - ant suggestions?
  • 290 Answers
Hollow ice is a sign that the icemaker is not getting enough water.
You will want to make sure there is enough water coming to the fridge and any filters in the system are clean.
If you need help checking it, please post the complete model number from the fridge and I can help you more.
Posted on Nov 24, 2007
  • Michael  Lindley
    Michael Lindley Nov 28, 2007
    If you have a good, hard flow of water to the water valve, then make sure there is no ice built up inside the fill tube going into the icemaker.
    If all is clear, feel inside the icemaker and make sure the ice is frozen,
    Pop the front cover off the icemaker.
    If the inside face of the icemaker is metal,
    Make sure the adjustment arm is sitting about half way between the + and - synbols.
    Rotate the large gear clockwise until the icemaker starts running on it's own.
    Listen for the watervalve to open.
    It should stay open about 7 seconds.
    Feel in the icemaker and see if all the sections have filled to just under the ejector arm. If not, replace the water valve.
    If the inside face of the icemaker is plastic,
    Use an insulated wire with about 1/2" of exposed wire on the ends to jump between the T and H holes on the front of the module.
    This will start the icemaker in a cycle, leave the wire in place 5 seconds then pull it out
    Follow the same directions as above to check the water fill.
Ice maker does not make much ice
The amount of ice usually deepens on the freezer temperature. The colder it is the faster the ice production. Assuming the ice cubes are full size and not hollow.
Jun 30, 2015 | Refrigerators
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Jul 25, 2009 | Maytag MSD2454G Side by Side Refrigerator
Water is leaking into fridge, ice maker making hollow ice
Make sure when the icemaker fills its not causing the leak ...... other than that you have a clogged drain in the freezer section .... easiest way remove everything unplug for 24 hrs with door open .... manual defrost ....hehehe ..... plug back in u should be ok if reoccurs call for service
Jul 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
most older fridge's thermostats are in the ice maker,replace it and it will most likly solve most of your problems.i happen to have a ice maker that will fit some models.if you need it.but check my facts 1'st
Jun 09, 2009 | Refrigerators
Ice cubes are hollow.
some fridges are designed to make hollow cubes where they always hollow or just recently
Apr 13, 2009 | Refrigerators
Freezer too cold and not much water. When it is empty of ice check the water level in the ice tray. Probably not even halfway up. Unplug fridge for 8 hours and plug it back in. Need more help please live chat. If this has helped, please rate as fixya.
Nov 19, 2008 | Whirlpool Gold Series GI15NDXT 15"...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Magic Chef (CSD2610KRW) Top Freezer Refrigerator Logo
522 people viewed this question
Top Magic Chef Refrigerators Experts
Level 1 Expert
John Tripp
John Tripp
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
