Question about Compaq Computers & Internet
How do you make your DVD drive run externally, on laptop?
How do you make your DVD drive run externally, on a laptop?
I'm looking for maybe a switch on the inside of the drive that tells the computer that it's pushed in all the way.
Thanks
  • barrymtm May 11, 2010
    Some drives come with a built in mini usb port that can then be used externally but most don't. How are you trying to connect the DVD drive? What model Compaq do you have?
  • 32 Answers
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
26
Posted on Aug 01, 2009
How do I connect my laptop to a Monitor
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 06, 2012 | HP Pavilion dv9000 Series Laptop DVD Drive...
Not able to view dvd on laptop with external LG GP08......
I am gonna assume that you mean a DVD movie here and it maybe that you do not have the codecs installed you'll need to download and install K-Lite Codec Pack. Make sure you uncheck the box to install Media Player Classic
Sep 03, 2011 | LG SecurDisc 8x External Double-Layer DVD...
My dvd disk drive will not open anymore. The light on the side does not turn on either. When I try to poke the hole on the side the drive doesn't open. It seems it is stuck shut. Is there any way to open...
make sure that the dvd drive is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 30, 2011 | ASUS Computers & Internet
Toshiba A 45-S150: How to boot from external dvd drive?
Remove the disk-drive from the laptop, and connect it to another computer.
Copy all the files from the recovery-media onto the disk-drive.
Reinstall the disk-drive into your laptop.
Run the recovery software from where you copied the files onto the disk-drive.
Jan 01, 2010 | Toshiba Satellite A45-S150 Notebook
I cant get the dell vista os reestore disk to boot up
Use external USB CD/DVD Drive to run your Windows Vista Operating System to Restore Disk.
Maybe your Built-in CD/DVD cannot read or access your OS.
If you don't have this device, you try another Windows Vista OS Disc.
Sep 15, 2009 | Dell Inspiron 1721 Notebook
No DVD sound with my LG GP08 Super Multi Drive
Hello, Phil,
I have the same problem on an Asus EEE Pc... Is your Toshiba running Windows 7? This is maybe the reason, because external drive is not compatible with this OS. That's what I heard from LG...
The drive works perfect on my Asus laptop with XP!
Please keep me informed if you solve this problem.
Regards,
Andre
Sep 06, 2009 | Computers & Internet
Ways to load OS
External Floppy disk drive or External CD/DVD drive. Might be easier to just replace the internal drive.
Feb 17, 2009 | Dell Inspiron 4000 Notebook
Upgrading dvd drive
Yes pretty easy but maybe expensive a better way perhaps would be to get an external DVD/RAM and plug it in via the USB port... that way ya would have two...
Jul 29, 2008 | Toshiba Satellite A105 Notebook
External dvd writer
You would be able to boot from the external drive but you will not be able to run an operating system from it. It would allow you to install another operating system if that is what you mean? If i understand you correctly though, you would like to say perhaps, have windows xp on your laptop and maybe run windows vista on your external? Maybe get to choose which one to run. This is not possible. Sorry. I hope this helps!
Dec 05, 2007 | NEC Versa FX Notebook
Computers & Internet Logo
15 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
