Question about Generic Memory Computers & Internet
What types of problems can occur when new requests are made on electronic diary systems.
My 2005 GMc envoy stopped when I stopped at stop sign the service brake system warning keeps coming on when push brake pedal. Gear shifter won't move out of park and it will not start.
Hello Kammy ,you have electronic problems ! Your best bet would have it towed to a qualified repair shop .
SERVICE BRAKE SYSTEM
Refer to Brake Warning System Description and Operation !
The instrument panel cluster (IPC) illuminates the brake warning indicator when one or more of the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination.
• The electronic brake control module (EBCM) detects a low brake fluid condition. The IPC receives a class 2 message from the EBCM requesting illumination.
• The EBCM detects an ABS malfunction which disables dynamic rear proportioning (DRP). The IPC receives a class 2 message from the EBCM requesting illumination.
• The IPC performs the bulb check at the start of each ignition cycle. The brake warning indicator illuminates for approximately 3 seconds before turning OFF.
• The IPC detects a loss of class 2 communications with the BCM or with the EBCM.
When there are electronic problems the computers will not allow the vehicle to start , hooking up a factory or professional scan tool to see what the problem is is the first place to start .
Apr 14, 2017 | 2005 GMC Envoy
How do you change your password on a youniverse keep safe diary
You push the reset button on back under the batteries pannel if you dont remember the password. Then after that (or if u just want to change your password, open the dairy, push the change password button, while diary is still open type in your new desired password then simply, press the change password button again and shut the diary. You are now all set
Jan 29, 2011 | Toys
How can iget the my password
Please try options as below :
3.HELL0_0KITTY
4.HELLOKITTY123
5.HELLO_KITAY
6.CUTIEKITTY
7.HELLO_CUTIE(UR BIRTHDATE)
8.HELLOTTKITTY
9.BESTIEHELLOKITTY
10.HELLOAIMKITTY
11.AIMHELLOKITTY
12.HELLOKITTYON_AIM
13.HELLOKITTYGOODIES
14.DABESTKITTY_HELLO
15.CUTESTKITTYTHANG
16.SEXYHELLOKITTY
17.HELLOKITTYAIM
18.H3LLOTH3R3KITTY
Jul 07, 2010 | Blue Box Hello Kitty Electronic Password...
Harvest moon ds isnt working when i try to load both diaries but they both freeze im not sure if year and dat matters but its winter 9, year 2 need help please!!
Ah...my favourite game.
Try to restart the game on one of the diaries.Turn it off instead of saving.Reload the diary that is the higher level. If this doesn't help then try to play on the new game diary until you can save. Save the game then try to reload the higher level game. This should work. If not you may be having problems with the DS itself. I've heard alot of problems recently about the internal clock.
I'm thinking that you've just hit a glitch in the game and that this should work though.
Good luck.
Aug 16, 2009 | Video Game Consoles & Games
Looking for master password for my secret diary ds game
The Master Password to the game is oxygen. After you type that in you need to pick a new password!!!!!
Mar 28, 2009 | Nintendo DS Lite
Password
Take the battery cover off. In the top left corner is a teeny-tiny hole. Depress it with the end of a paper clip that has been unfolded. This will reset the diary so you can enter a new password
Mar 09, 2009 | Blue Box Hello Kitty Electronic Password...
Hello Kitty Electronic Password Diary
Take the battery cover off. In the top left corner is a teeny-tiny hole. Depress it with the end of a paper clip that has been unfolded. This will reset the diary so you can enter a new password.
Dec 30, 2008 | Blue Box Hello Kitty Electronic Password...
Lost password
Remove the battery cover and locate the teeny-tiny hole in the upper left hand corner. Using an unfolded paperclip, push into the hole, then reset your password.
Nov 29, 2008 | Blue Box Hello Kitty Electronic Password...
Computers & Internet Logo
751 people viewed this question
Top Generic Memory Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
marley mcelhinney
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Generic Memory Computer and Internet Expert? Answer questions, earn points and help others
