Whirlpool RS675PXBQ2 wiring diagram link below.
http://www.appliancepartspros.com/parts-for-whirlpool-rs675pxbq2.html
Hope this help :-)
I’m happy to assist further over the phone at https://www.6ya.com/expert/latoya_8ed1bf3dc615c15d
SOURCE: I need a wiring diagram for a whirlpool rf356bxdw0 range
After a lot of persistent searching, I found a wiring diagram on the internet.
SOURCE: need wiring diagram for whirlpool range model#
Check the "find manuals" section at the bottom of the FixYa home page.
Best regards, --W/D--
SOURCE: A wiring diagram for a Whirlpool Mod. LGV6848AWO
look in side back cover or front bottom panel
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%203169519.pdf
Try this link. any questions please let me know!!
Good luck!!
I will try to locate a wiring diagram for your model ET19RKXFN01 but to change the defrost timer you will only need to know its location. Here is a link to the repair parts=> ET19RKXFN01_Repair_Parts_List
Go to page 5 of the repair parts list and you will see item number 4 Then on page 6 of the parts list you will see the timer part number beside the item 4. That is your defrost timer part number 2193084 Defrost Timer
Your refrigerator is an older model and may have the wiring digram in a packet behind the kick plate in the front near floor. Changing the defrost timer will not require use of a wiring diagram. Simply remove the old timer and replace the new defrost timer by plugging it into the wiring harness. The defrost timer can be found behind the control panel inside the fresh food compartment where the controls are located above the top shelf. If you have questions just let me know, Thanks Sea Breeze
