Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Won't drain or spin
My cabrio washer will not drain or spin. The motor seems to run though
  • 69 Answers
The timer may need to be replaced.. it might not be clicking on the spin cycle. try moving the dial manually to the spin mode.
Posted on Jul 30, 2009
6200 whirlpool cabrio, Ld error code. Usually, cancel, start corrects problems. Now seems like it won't spin. Tried unplugging and restarting, that also didn't work.
most likely a clogged pump drain find it below the drum usually under a plastic lid bottom left if not under the lower panel below the door
find the 3 screws and remove the cover panel and clean the pump by twisting the pump valve cover counter clockwise
WHIRLPOOL CABRIO WASHER ERROR LD The Cabrio Washer LD error code stands for Long Drain which means the control has recognized the water in the tub is not draining fast enough during the cycle.
  1. Make sure the pump and drain hose are clear of debris that would cause a blockage.
  2. Check the impeller on the drain pump and make sure its not wobbly or busted.
  3. Remove the tub hose from the pump to the tub and check it for blockage.
  4. Make sure the pump is running when and getting the proper voltage when it should be.
  5. If all the above checks out then replace the drain pump motor.
Feb 14, 2018 | Whirlpool Washing Machines
My washer will not drain or spin and I get the code ld but if u mess with the motor it will run again
check the wires going to the motor they could be broken or the plug for the motor could be loose
Mar 19, 2014 | Whirlpool WTW6400SW Cabrio Washer
My whirlpool cabrio washer has started shutting off half way through the wash cycle...won't drain and spin...could the motor be overheating or is there something else I can check?
Most likely the cycle timer needs to be replaced. it is basically a clockwork device that that has cogs attached to a spindle. if you check the schematics for your product you will find the part no. etc. any servicing of course needs to be done wit the power disconected
Jan 20, 2013 | Whirlpool WTW6400SW Cabrio Washer
What does the "OL" mean on the cabrio washer? it doesn't seem to be spinning out the water either
my cabrio is having problems too it won't go through a full wash cycle ,when it's time to drain it stop.I cleared the drains and even took the drum out and found some socks,then I started it today and it worked till the drain cycle .I also had it run a diagnostic and stopped on C8. I hate laundermatts
Aug 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer will not spin and drain
The load was probably unbalanced enough to trip the safety and shut the machine down. Have you tried running it again empty since then?
Nov 15, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio won't spin and has standing water
The coupling might have broken in place and will not allow the motor to do its job. It's a $7 part that goes on the motor shaft.
Jun 28, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer does not spin
I had the same problem in october- my had a bad wiring harness, some board problem, and a bad sensor. if it hadn't been under warranty the cost of parts alone would have been over 1000bucks.
Dec 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
533 people viewed this question
Dan Webster
Dan Webster
Sal De
