Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Genie garage door opener chain adjustment?
My door will not raise or lower. The motor is working but the chain may to be slipping possibly because it is loose? I can't see how to adjust it. Anyone know how to tell me what to do?
  • bobo12577 Aug 23, 2009
    Finally opened it up this morning. It is not stripped. Didn't find any shavings or debris in the housing. Door will lower, but will not raise. Could it be a spring or something else easy to fix or should I just get a new one?
    President:
  • 3,197 Answers
Remove the cover and check the main drive gear. It is most likely stripped.
Posted on Jul 30, 2009
Cannot open my garage door manually after I disengage it from the garage door opener (chain drive)
They are not light weight but there is no reason if the motor can raise it, then you cannot raise it by hand.
Feb 05, 2016 | liftmaster chamberlain 1/2 hp chain drive...
Fix my Craftsman 139.53973SRT garage door opener? When the button is pushed, the motor runs but the chain doesn't move. When I get on a ladder and try to pull the chain (help it along) it will move o
Pull the cord that releases the traveler from the door and manually raise and lower the door to make sure the door isn't binding anywhere. Then actuate the opener and watch to ensure the traveler moves along the rail. If this is all successful, you may need to adjust the sensitivity of the opener.
Nov 26, 2014 | Building Materials
How do I stop my craftsman garage door opener from whining? it whines on the inside of the motor
is it gear or chain, is it genie or liftmaster. check for smooth operation of door by disconnecting motor. check tightness of cable/chain running down rail. this may be putting undue stress on gears and ruining plastic drive gear.
Oct 20, 2014 | Building Materials
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Garage opener try to close door when door at close position
There are upper and lower limit settings, it sounds like you have the lower limit set to low. Adjust it so it stops the door as it contacts the floor and see if this solves the problem. It is possible these limit controls are damaged and will not stay set. If that is the case it may be best to replace the opener if you cannot find a replacement.
Apr 06, 2014 | liftmaster Chamberlain Garage Door Opener...
Electric motor hums but does not open or close garage door
If it just hums and not actually run. Then the trolley is jammed against one of the stop bolts.
Mar 26, 2014 | Building Materials
I just installed a Sears Craftsman 1/2 HP Garage Door opener. As I was doing the adjustment to keep the door closed, it closed too tight. I disengaged and confirmed the door arm was set wrong so I fixed...
Use the emergency release handle to release the door. Run the opener to the open position until it stops. Close the door until it stops. Now re engage the the door.
May 04, 2017 | Sears Genie Garage Door Gpwk12 Wireless...
My mom has a 1/2 hp chain opener that was installed in 2000 or so. It had recently begun overdriving both closing and opening (so button had to be pressed once to stop it). I tried adjusting the raise...
Remove the cover from the motor unit and you will see the limit switch assembly. If you watch the operation I think you will understand it and be able to adjust it properly.
Nov 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
The motor on my Genie Chain Glide garage door operator runs but the chain does not run or move.
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Dec 29, 2009 | Genie Company Genie PowerLift Excelerator...
I have a Genie garage door motor. Whenever I try to open the garage door, the door opens about 5" and then simply stops. What's going on?
check the track for tight spot it will stop if it is not stright, too close or too wide also check cable or chain for dirt lubracate all
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
782 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
