Question about Coleman 10' X 10' Sundome Tent 9160K101
Ripped outwell tent
We have a ripped outwell tent how can we repair it? The tent is an old blue indiana 4 outwell tent which is very tricky to put up- my other half has managed to rip it when putting the pins into the bottom of the poles. What are we doing wrong? We follow the instructions but there just does not seem to be enough 'give' in the poles to do this.
Log onto http://www.imagescotland.com/scottishmountaingear-home.asp
this is outwell's recommended repairer!
Good luck
ps. putting the pins in is very tricky - needs strength and patience!
Posted on Aug 20, 2009
    Problem Solver:
  • 17 Answers
Wow, that is a nice tent. The best thing I have found for repairing a tent is Gorilla Tape. This stuff is tougher than duct tape. It's not going to be pretty, but once a tent is ripped, it's very hard to seal/fix. Gorilla tape is tough, waterproof and indestructible.
As far as the poles going into the pins, it takes a lot of faith in bending them to their max. The easiest way I've found is to put one side in, then slide the pole sleeve back towards that pin while I wrestle the next side in. The pole is going to bend crazily, but that's ok. The first pole I usually just lay on the ground, so I can manipulate it easier. Good Luck, Alley
Posted on Aug 04, 2009
Where can I get tent replacement poles for a Ted Williams blue canvas tent sold by sears as they don't have them?
How old is it? (Canvas suggests that it is very old and has not been produced for many years.) If it is more than a few years old, the only way is to find a supplier that will make custom poles to fit most tents. But that can be expensive, and so you might want to just find a new tent that you like. Don't spend a ton of money on an old and possibly very leaky tent unless you know that it will keep you dry.
Feb 27, 2015 | Camping, Backpacking & Hiking
American camper tent 2455 setup
Finally figured it out through trial and error. This right here is the only correct explanation given anywhere on the net.
First, make sure you have all of your poles. There will be 4 straight green ones, 4 straight blue, 4 straight burgundy with plastic feet, 4 curved yellow, 2 small orange arches, a straight pink and a straight white.
Before you start putting the poles together, stake the tent down at every loop point around the base of the tent. There should be 10 of them. Make sure they're fairly tight and the floor of the tent is taught and flat but not so tight that you tear the tent at the seam. Stake 1 corner first. Then put the second stake through the second loop in order and using a firm pressure, pull away from the first stake, along the line of the tent base, make taught and push the second stake into the ground. Repeat until finished.
The first pole assembly uses in this order, going out from the yellow arch, which is in the center. From one side of that arch, add one green, then a curved yellow, then another green and a burgundy at the bottom. Do the same from the other side of the center arch piece.
This arch outlines the door and goes through the 3 loops on the front of the tent, around the door, so the poles hold the tent up. the loops at the bottom are not for the poles. Every loop around the bottom are where the stakes go to hold it down. For now point the feet towards the back of the tent wherever they will stand on their own. You can fine tune it and firm it up once you get the second arch in place.
All green ones should now be used up.
For the second arch, do the same thing but use the blue instead of the green. So from the one side of the yellow arch, 1 blue, 1 curved yellow, one blue and one burgundy. Same order from the other side of the arch.
Now all the poles should be used up except for the straight pink one and the straight white one. These two go together to make a straight pole that goes through the metal loops attached to the yellow arch pieces and locks the two arch assemblies apart at the top.
Now this takes some maneuvering and some word smithery to describe but what you want to do is make sure the feet of the front arch assembly, are pointed towards the back of the tent and stop at the side. The back arch feet will point towards the front of the tent. They both stop about 6 inches BEFORE the center tie down loop on the SIDES of the tent, on either side of the center loop. The front arch will actually lean forward, with the feet pointed behind it and wedged into the ground, right up against the tent at the bottom, move it around until you have a nice firm feel to it. Same with the back arch but this one will lean away from the back of the tent and the feet pointed towards the front. Once you get the back arch into place, it will really firm up and won't budge.
Another way to describe it would be that the two arch assemblies feet will point towards each other at the side of the tent, about 6 inches before they reach the center loop on either side.
Hope this helped. =)
Posted on Jul 04, 2015
Apr 09, 2013 | Sport & Outdoor - Others
Apr 09, 2013 | MSR Family Tents
Instruction for setup of American Camper tent 8x11
Aug 28, 2012 | MSR Kamp Rite Double Tent Cot
I need assembly instruction for 8 person cabin dome tent with screen house
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Oct 23, 2011 | Coleman 10' X 10' Sundome Tent 9160K101
    No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
    I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
    So to put it up.....
    lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
    Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
    Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
    These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
    Enjoy
    Jul 31, 2011 | Sport & Outdoor - Others
    We are looking for some instructions on erecting the colorado 5 outwell tent. Can anyone help xx
    Visit this site for the information you are requesting: www.ukcampsite.co.uk/tents/p/Outwell-Colorado-5/369
    Jul 21, 2010 | Locks & Locksmithing
    I NEED INSTRUCTIONS TO AN OLD AMERICAN CAMPER TENT IF ANYBODY CAN HELP ME ON MY SEARCH TO FIND SOME INSTRUCTION
    Jul 12, 2010 | MSR Family Tents
    How to put up a tent- ozark trails 16x12
    I have this tent and have successfully put it up a few times. It's a big tent but it's frustrating to put up sometimes. Plan on having several people to help you. I find that it greatly helps if there are a total of 3-4 of you.
    The poles are color coded. The center support are red rods. The two side supports are blue with the graphite looking rod that goes through the tent.
    Spread the tent out on the ground and try to square it up and make it even. Run the center pole through the top and connect to the curved pieces which then connect to red dot poles on the side. Hoist the whole thing up. Have two people hold those poles for a while.
    Get the bue poles into the black couplings and put the graphite looking rod through the tent. It will be a little tight. Hoist the blue poles into position. The bottom of the blue dot poles should be about two feet from the center. They extend outwards at about a 30 degree angle. Keep your center people holding the center poles and let the two blue dot pole section extend outwards. You'll start to see a tent shape. Your center holder people may need to keep and eye on the poles.
    Now, start trying to get some stakes in. Work the corners. Once those are in and things start getting tight, it should start to hold on its own. Work all the stakes in and make adjustments to all the poles as necessary.
    Extend the red dot poles up until the roof is at the proper height. I tend to do this last.
    The fly basic basically clips on into holes on the blue dot poles.
    It's kind of a pain to set up but its a big tent and works well once it is up. Good luck.
    I took a ton of pictures after I got it up the first time. As I took it down, I shot the pictures. Then, I reverse the order and printed them to a book and now sort of use that as my manual.
    Have fun.
    May 20, 2010 | Computers & Internet
    Coleman 10' X 10' Sundome Tent 9160K101 Logo
    1,052 people viewed this question
    Top Coleman Sport & Outdoor - Others Experts
    David Payne
    David Payne
    Vernon Taylor
    Thomas Perkins
    Thomas Perkins
    Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
