Question about Denon DP-DJ151 Turntable
I have a Denon DP-DJ151 and the power won't turn on. Is there a fuse with these turntables that might be blown?
  • 69 Answers
Ive not worked on a denon deck but there will be internal fuses.on techknics you remove the platter then remove the caseing to uncover the board and the fuses will be on there,make sure to use the right ones though as they protect main board gd luck
Posted on Aug 07, 2009
Sound from 1 side when i play records, i have 2 other turntables they work fine
Have you measured the cable from the beginning to as far as youncom on the cartrdigde and first clean and set everything as is supposed to be. One channel is or a needle or connection problem, certainly when it works works with other needlestuff
Mar 06, 2014 | Denon DP-DJ151 Turntable
I need a cartridge for my Denon DP-DJ151 Turntable, and I can't find one anywhere. Is there a universal I could get? Thank you!
You can fit any cartridge as long as it will fit the headshell. Just look around for something like the Denon cartridge mount.
Sep 19, 2013 | Denon DP-DJ151 Turntable
Need cartridge for my denon dp-dj151 turntable
You can use any cartridge as long as it will fit on the headshell.
Denon dp-dj151 - won't turn on.
Have you got a volt/ohm meter? if you have then test the switch for connection. If that's good test for voltages with the meter.
Jun 09, 2013 | Denon DP-DJ151 Turntable
What cartridge to use on Denon DP-DJ151?
Anything that will fit the headshell. You can spend a few pounds or few hundred on them. It depends what kind of quality you want.
Dec 04, 2012 | Denon DP-DJ151 Turntable
I need a copy of DP-DJ151 owners manual
Do you really need a manual for that? All you need to is fit the cartridge to the headshell then connect the wires to it. If you don't know which of the wires is left or right, just connect it to a switched on amp then with your finger touch each wire one at a time. You should hear a loud buzz on the left on one wire and on the right on the other. The other two wires might buzz a little on there channels, but it doesn't matter as they are earths. The new cartridge will tell which are the channels on it and the earths.
May 26, 2012 | Denon DP-DJ151 Turntable
Platter turns slow
This turntable design has a direct drive system instead of belt drive (two types). If this unit has been in storage for some time, it has most likely been at hot or cold tempuratures - not good for any electronic/mechanical system.
My guess is that the direct drive motor needs to be rebuilt - internal friction is probably keeping it from operating at proper speed. Best to consult with a repair shop that can handle direct drive turntables - several on the internet, if you cannot find one locally.
BTW: You can find a manual for this at : http://www.vinylengine.com/library/denon/dp-45f.shtml
Best regards,
Andre
Apr 06, 2008 | Denon DP-47F Turntable
Will not turn on (no rotation of turntable)
theres not much to a turntable if belt is on and you can turn the table freely then i would guess there be a blown fuse inside
Dec 31, 2007 | Denon DP-29F Turntable
Denon DP-DJ151 Turntable Logo
231 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
