Dvd rw not detected in Bios and not working V5535 Fujitsu
Recently I changed HDD on my Fujitsu V5535 so laptop without any OS as old HDD failed. At the moment laptop can detect HDD but not DVD RW. I tried DVD RW on the other laptop and it works perfect. As soon as it goes back to original machine Bios can't recognise it. Is it software or hardware problem? I can't install OS so would appreciate any solutions to solve the problem.
Regards
Terry
    Problem Solver:
  • 15 Answers
You could try removing the cmos battery in the bottom of the laptop look in manual to see how or you could install using usb external dvdrom set bios to boot from usb dvdrom first
Posted on Jul 30, 2009
Removing cmos battery v5535
Here is a YouTube link - https://www.youtube.com/watch?v=Y-35mUbeQnQ
Here is a text and picture link - http://sigg3.net/entry/1395
Both links require you to disassemble part or most of the laptop. Keep your screws labeled as you remove them so you can get them back into the correct places later.
Sep 06, 2014 | Fujitsu Computers & Internet
No disk drives found/no os found. hdd hitachi sata not installed in bios. bios does not allow changes in this field.
Its a hardware problem, it seems that your laptop fails to detect your HDD as your HDD is damaged and is unusable. Replace it with another HDD or purchase a new HDD.
Jan 18, 2014 | Computers & Internet
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
Problem with fujitsu laptop esprimo v5535
I suggest doing a manual reset, and if all fails start by removing certain hardware equipment such as memory, wifi cards, etc. If you need more info, please ask.
Feb 07, 2010 | Fujitsu Siemens Computers & Internet
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Fujitssu/Siemens Esprimo V5535 - DVD/CD drive will not write -
turn laptop over if you look down the centre of the width of the dvd rom you will see a small star screw remove screw and pull out dvd rom reversal to replace
Sep 14, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
I change dvd-rw, HDD, reset Memory, but I can't load system.
I'd try a new ram stick or if you have 2 in remove one at a time & reboot.If it works,that's your problem. If not then it's safe to say it's the motherboard.
Jul 10, 2009 | Computers & Internet
Acer 4520 cd/dvd driver problem
Try to use another DVD. you told you tried you old DVD from your toshiba. maybe is not compatible.. try in another.. then use your DVD in another laptop if the same from problem.check your board and DVD connection...if this under warranty bring to warranty..
if in Bios also can not detect this is hardware problem...
May 28, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Wont boot
go to BIOS and enable the secondary drive auto detect.
if you manaully set the drive to primary, secondar. the system should be able to detect it as you have set it. if you select cable select or auto. the sytem will put the drive connected to the end of the IDE cable as primary.
Apr 02, 2009 | Intel Motherboard
Laptop not booting
sounds like you have not only a vista issue here, but a potential boot sector virus...if it won't boot from cd, then there's a major issue with that machine.Fujitsu to the rescue, looks like to me
Mar 20, 2008 | Computers & Internet
Computers & Internet Logo
389 people viewed this question
David Payne
David Payne
