Question about Microsoft Xbox 360 Console
Ethernet has stopped working. there is no problemb
Ethernet has stopped working. there is no problem with router . we did have thunder stroms
    Problem Solver:
  • 13 Answers
Thats not good bye a new cable or it destroyed the connection
Posted on Jul 30, 2009
I have Sony Bravia KDL-46HX800 3D TV. My Ethernet connection stopped working. I can't get IP, my Sony blueray player doesn't have such problem (it is connected to the same net. switch). TV say
use a straight thru to connect directly to the router. Cross overs are typically used when connecting PC's directly together or daisy chaning routers or switches. Try a different port on the switch? Also from a pc, go to the DOS prompt and try and ping your TV. If your TV IP settings are all correct, and your network equipment is working, your should get a response from pinging your TV. If you don't, I would suspect a problem with your TV Enet port.
Jan 05, 2013 | Sony BRAVIA KDL46HX800 46 1080p LED 3D TV...
No Internet after thunder storm
possible the storm may have blown out your ethernet port on the desktop, router, or modem. It has happened to me once before.
Jul 02, 2012 | Acer AX1900-582G50mi PC Desktop, Intel...
Linksys E3000 Wireless Connectivity Problems the router is excessively hot too. Can connect with ethernet cables I have cable mode and the cable company sees my lan card I can get internet connected via...
That excessive hot temperature of your router is not a good sign, it means that something is wrong with it and the problem is hardware base and in just a few more days or weeks the router will eventually stop working even when using ethernet cable.
The best thing to do here if the router is still new and under warranty is to have it replace from store or from where you purchased it.
Mar 04, 2011 | Linksys E3000 Wireless Router
Lenovo WinXP - Ethernet port issue
Hi. Try to check the steps as give below.
  1. Check the ethernet port with other spare wire if you have to check if it is a wire problem or if it is itself your ethernet port.
  2. Try to connect your ethernet port directly to the router to make sure ethernet port is working and there is no connectivity issue with the switch.
  3. Try to check the System BIOS settings and see if it is not disabled from there.
  4. Lastly download any free Live OS of Linux and boot your computer using it. See if the ethernet card is working or not.
Steps from 1-3 is for checking physical connectivity of the ethernet port and the last step is for checking OS issue. If network card do not work with Live OS as well, you can directly come to conclusion that its ethernet card that is not working properly and you need to get is repaired.
Cheers!
Apr 14, 2010 | Lenovo Thinkpad T60 Notebook
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Oct 13, 2009 | Cisco 857 Router (CISCO857K9)
Router quit working after storm
if that router stop working by thunder storm then buy a new one.. nobody can fix it.. or maybe to go electronic shop to refer to them...
Jul 15, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
Connection to iMac not working
the easiest way is hard wire a windows laptop and use the CD that came with the router.
Oct 13, 2008 | Microsoft Broadband Networking MN-500...
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Microsoft Xbox 360 Console Logo
57 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
