I have a 1 Terabyte Iomega hard drive model # MDHD10T-UT Serial # JPA80302B8 I just stopped showing up on my desktop and I can not mount it. I have tried Disk Warrior, Data Rescue II and FileSalvage. Still no luck. The light for the drive goes on but it doesn't show up as connected no matter what I do. Can the drive be repaired?
  • duckpondale May 11, 2010
    is it a internal harddrive what is your os if vista you can go into computer managment storage activate disk and format
The Drive is not damaged - the power supply has failed it has happened to me 3 times.
Currently Im trying to get additional power supplies from Iomega. If I get additional info I will updated
Posted on Aug 03, 2009
  • msarr Aug 06, 2009
    Iomega Online Store.
    To purchase that power supply you will actually need to contact our technical support divison. Their phone number is 800-940-6392 Option 2
    Let them know that it is your first time calling and are wanting to purchase a power supply.
Do you still have that drive unit??? I need the pcb willing to buy it
vasidj@yahoo.com
Posted on Jan 12, 2010
Seagate Barracuda 7200 1TB spinning but not mounting
Man it sounds like it just died on you out of the blue... Maybe you had a power surge or something and you didn't know it.
Jun 30, 2012 | Iomega 1TB Desktop USB 2.0 Hard Drive
Hey i brought a iomega select desktop 1.5 tb hard Problem with the Iomega 1.5TB Desktop USB Hard Drive hey i brought a iomega select desktop 1.5 tb hard drive from argos got home and transferd all info...
  • Plug your Iomega hard drive into one of your computer's USB port.
  • 2
    Click the "Start" button and go to the "Run" field. Type "Devmgmt.msc" into the Run box and press the "Enter" key.
  • 3
    Go down to the bottom of the device manager to the "Universal Serial Bus Controller."
  • 4
    Click on the little + (plus) sign to expand it. Look for an entry with a yellow exclamation point and click on it. Click the "Install the software automatically (Recommended)" button and then click the "Next" button.
  • 5
    Click the "Finish" button when the installation has finished. Go to the "My Computer" folder from your "Start" menu and locate the Iomega hard drive icon. Double click the icon to gain access to the external hard drive.
  • Mar 10, 2011 | Iomega 1.5TB Desktop USB Hard Drive
    My iomega terabyte fell on the floor... now it makes a clicking noise and its not recognized in the computer... and it is turning off after 2 min when I try to start it.. what to do?
    Ok this is tough because sadly it sounds like the hard drive is phisically damaged. you will need a data recovery specialist to retrieve your data they can be found easily enough on google but they dont come cheap so weigh up the expense to the importance of retrievel. the problem is if it was software or bad clusters theres algorythem software out there to put it right but as it is making a noise it would show that the reading arm inside have probably broken meaning the hard drive needs to be taken apart and the disks reading individually hence the specialist needed
    Jan 19, 2011 | Iomega 1TB Prestige External USB 2.0 Hard...
    Terabyte iomega hard drive, the two lights are flashing red, fan not operating, no access via My Computer.
    An external storage-device has four major components:
    * the USB cable
    * the power-adapter
    * the disk-drive inside the enclosure
    * the USB-to-disk-drive adapter inside the enclosure.
    One of these components has failed.
    Try a different USB cable.
    Try connecting to a different USB port on your computer.
    Try connecting to a USB port on a different computer.
    Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
    Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
    Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
    Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
    Nov 08, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
    Iomega terrabyte drive MDHD10T-U2 does not mount, ticking noise
    I followed richiegrier solution above - my drive began clicking and did not run. I determined both drives worked and that it was the power supply (apparantly I'm not the only one with this problem. I purchased a NexstarMX dual HDD enclosure. I opened it, flipped the switch up to the JBOD mode, and installedd my two drives. Initially the configuration recognized a single 900+ GB drive, which was empty. I used the safely remove hardware icon, powered down the unit, and switched the positions of the drives - VOILA!!! the computer recognized the drives and all the files are back online, precisely. A couple caveats - the drives when in JBOD mode are A and B, although there is no obvious way to tell them apart - Like a book, A appears to have the directory for the combined drive. When mounted in reverse, the computer did not read the directory, and assumed it was empty. When I reversed the drives, my drive came up, flawlessly with no input from me. THANK YOU. Do not format or create a new partition or you will lose data. I also purchased a 2 TB drive for back up, and will immediately begin a second copy of all the data on this drive so I do not have a disaster. Thanks again for saving me from disaster.
    Dec 07, 2009 | Computers & Internet
    1T external will not mount on Mac OSX. It worked fine but just stopped. Have tried other computers and cables but nothing. It is getting power. Model #MDHD10T-U2 Serial #JPA7470874
    This needs to be formatted before it can be used on a Mac.
    1. Launch Disk Utility by selecting ApplicationsUtilitiesDisk Utilities
    2. Click on the active partition to select it.
    3. Click on the Erase tab.
    4. Select MS-DOS (FAT) from the Volume Format drop-down menu.
    5. Click on the Erase button.
    6. When Disk Utility is finished erasing the disk, click on the active partition and ensure that the Format field at the bottom of the Disk Utility window says that the volume is MS-DOS (FAT32).
    7. You can now quit Disk Utility.
    Oct 13, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
    I HAVE A IOMEGA HARD DRIVE FOR MY MAC (TIME MACHINE) MODEL NO. MDHD10T-UE AND HAVE BEEN USING IT FOR SOME TIME HOWEVER IT HAS NOW GONE OFF MY SCREEN AND I CANNOT RETREAVE IT I HAVE TRIED CHANGING THE...
    Hi I had one which my son connected the wrong power cable to an toasted the boards inside. I had to strip it and get new boards for the hard drives inside and replace them. i have managed to recover one of the drives ie 500gb.
    Oct 11, 2009 | Office Equipment & Supplies
    I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted...
    i have the same probleme . I have a Iomega 250GBExternal hard drive. The pins that connect to the hard drive via the adapter pack have broken. The serial number is 579233448 the model no is DA-30C03 and the p/N is 31426900. I wanted to know which is the correct product to buy please
    Sep 08, 2008 | Iomega (33090) 250 GB Hard Drive
    Failure to mount on desktop
    Iomega which is now a thing of the past were renowned for their fragility It may well have died
    May 23, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
    Computers & Internet Logo
    771 people viewed this question
    David Payne
    David Payne
