Question about HP Officejet Pro L7680 All-In-One Printer
Get General Error message when trying to scan in a PDF doc
The printer started giving me "General Error" message when I scan in a doc as a PDF to be saved on a memory device. JPEG will scan. Have been able to scan pdfs in the past without this problem. Is this an Adobe issue, memory device issue, or printer/scanner issue?
5 Suggested Answers
  • 111 Answers
SOURCE: Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Posted on Oct 08, 2008
  • 461 Answers
SOURCE: Scanned a word document, saved as jpeg file
By default all scanned documents are images (jpeg), OCR software converts the image to text for use with Word. I do not believe the scanner can tell what format to use without your input. More information is available here at HP's Online Support.
Posted on Dec 31, 2008
SOURCE: canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Posted on Dec 04, 2010
SOURCE: photo smart 2610 all in one scanner will not scan
My photosmart 2610 all in one . When I try to scan it gives me an error message that says "switch off and start again". I did this several times but it didn`t work. And i have install and run hp software for vista but is not work !What shall I do?
Posted on Aug 26, 2011
Problem scanning and saving pdf docs to desktop
I have the same problem. Try this:
If you set network path similar to: \\Server\Share you will receive an error. Try set path to folder located in network path eg: \\Server\Share\Folder
It works for me
Aug 29, 2012 | Office Equipment & Supplies
Lexmark prevail pro705 used to scan. now it will not. not sure why?
Try using the Lexmark Printer Home when scanning. If you have a PC, to access it click on Start > All Programs > Lexmark > Printer Home. You can scan to a .jpeg, PDF or .doc.
If you're scanning from the control panel of your printer and you're getting an error message, "Cannot Retrieve Application List", most probably your firewall is blocking your printer from downloading the applications. You might want to add the Lexmark files in the exception of your firewall. Click on the link on how to add exceptions to your firewall.
If you're trying to scan to email (email client), try to check this link: http://bit.ly/k0w0Hp
Mar 30, 2011 | Lexmark Prevail Pro705 Wireless All-In-One...
Impact s305 printer won't scan. it's stuck on "downloading application list"
Mar 11, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
General error with epson tx111
mw tanya saya punya epson TX111 gimana cara mengatasi general error ketiga lampunya nyala bersama sama..mohon bantuannya...
Oct 10, 2010 | Epson Office Equipment & Supplies
How to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Mar 02, 2010 | HP Officejet J4680 InkJet Printer
MP 210 printer maintance is in progress code 21140
Try refilling them. If they are empty, there is no way you will be able to print anything (or scan, or copy).
Mar 01, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
When I go to scan a doc to e-mail I get an error message that says (Not Set Up on PC) and I am unable to scan and send a doc via e=mail
Well as a workaround, as long as you can actually scan and save ... What you do is scan what you want, save it, then either save it as a PDF OR convert it to PDF After which you can then "Attach" it to any email you wish. I recommend PDF as most people have Adobe Reader.
If you can't scan to PDF, and it only saves as say JPEG, then get DoPDF http://www.dopdf.com/ To convert it from JPEG, JPG, BMP etc.
Feb 03, 2010 | HP LaserJet 3050 All-In-One Printer
I CAN'T GET THE SCANNER TO SCAN A DOC IN A PDF FORMAT.
Did u try to check the scanner option under scanners in Control panel. also how are you trying to scan the doc. try this open adobe acrobat and
In Acrobat, do one of the following:
Choose File > Create PDF > From Scanner.
Choose Document > Scan To PDF.
Choose From Scanner from the Create PDF menu on the toolbar.
Aug 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Hi Lynn,
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
189 people viewed this question
Seeker5211
Seeker5211
