Question about JVC AV-27020 TV
JVC PROJECTOR TV 61INCH
I JUST REPLACED MY LAMP LIGHT AND THE TIMER/PROGRAM LIGHT ON MY TV WILL NOT STOP BLINKING TO RESET THE LAMP....CAN ANYONE HELP......IM NOT RECIEVING A PICTURE BECAUSE OF THIS PROBLEM
  • 27 Answers
Try to checked the memory program I.C. located near the controler I.C. or it maybe put you on timer mode, try to go menu and checked the settings
Posted on Jul 30, 2009
Sharp projector timer unable to reset after replaced lamp.
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mar 07, 2015 | Sharp XV-Z9000, XV-Z9000E, XV-Z9000U...
When you try to turn on the tv,the timer lights blinks for about 20 seconds and then it goes to the lamp light blinking. i have replaced the lamp light 4 times in the past 2 years. it will last about 6...
Might be the connector of your lamp is losing. Need to reset the program of the unit if your reach the use hour of the projector this need to resetting of program meaning back to zero setting. There's in the manual how will you do it. But sometime it the secret of the service personnel to crack the symptoms.
Sep 08, 2011 | Televison & Video
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    Power will not come on. when tv is turned on light comes on then begins to blink, no picture and have to unplug to stop light from blinking.
    Depending on how old it is it may be a lamp issue. Check your manual to see what the blinking light means. if it's a lamp issue you may need a new lamp and have to reset the lamp timer.
    Jan 16, 2010 | JVC LT47X579 47 in. LCD TV
    My VPL-VW50 suddenly stopped working a couple months ago. It turned on, the fans started, then it would stop and a red light began blinking three times. I looked up the code and found that it needed a new...
    fisrt, did you reset the lamp timer? if the projector turns on again, go into the menu settings and reset the lamp timer. 3 flashes also mean that the lamp is too hot. let the projector go through it's cooldown mode and shutdown before you unplug it. remove the filter case and vacuum or blow the dust out of the filter. you can also blow the dust out of the projector (if any) with canned air. lastly, be careful where you buy lamps from. you get what you pay for. cheaper isn't always better.
    Dec 08, 2009 | Sony VPL-VW50 Projector
    I Have JVC Nodel HD52G887 and no picture after I heared a pop sound while watching. Can someone come and fix it and how much?
    You will have too replace the lamp, I have the same tv. The lamp costs around $200- they forgot to tell me the lamp runs on a timer and then when the time is up it goes and will need to be replaced. My tv is 3 years old and I am about to order my third lamp. Just remember after you replace the lamp that you go to the menu and "reset" the timer or it will not work even with a new lamp- all a money game
    Sep 24, 2009 | JVC TS-CL110UAA Projector Lamp
    Both Temp and Lamp lights blink red
    All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
    May 23, 2008 | ViewSonic PJ551 Multimedia Projector
    The Protectiopn circut is working
    Hi there
    Did you check that your lamp hours were actually reset ?
    Mar 27, 2008 | Mitsubishi XL1XU Multimedia Projector
    Blinking bulb light
    Hi there
    You must always reset the lamp timer when replacing a bulb.
    Dec 11, 2007 | Dream Vision CINEXONE Multimedia Projector
    JVC AV-27020 TV Logo
    293 people viewed this question
    Top JVC Televison & Video Experts
    Jaime Hernandez
    Henry  Thomas
    Henry Thomas
    Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
