Question about Honeywell Programmable Thermostat Heater
A/C won't kick on w/ Honeywell RTH230B
I switched out my old digital thermostat (Blue Dot factory one) for the Honeywell RTH230B programmable one. My old one has W,Y,O(Not in use),R,C,G and the new one has W,Y,G,Rh,Rc. I put the wires as follows W-W,Y-Y,R-Rh,C-Rc,G-G but my AC will not come on. The heat works fine as I tested it out but the AC symbol blinks as stated in the instructions for compressor safety, but when it goes solid the AC should kick on and it doesn't. I put my old one back up and it works fine. I've done the porcess twice trying to trouble shoot and make sure everything is secure and correct w/ no luck. What could be going wrong?
  • 614 Answers
Make sure you jumper R to rh. Russ
Posted on Jul 31, 2009
  • 3 Answers
Page 26 27 of the users guild states that thermostat has a fail safe preventing one system to turn on immediately after the other system has been on say you turn on heater to test then try to turn on cooling to test well cooling wont turn on immediately to prevent damage to system..
Posted on Feb 21, 2015
  • 86 Answers
Rh-24v heat Rc-24v cool
take your red wire hook it to Rh and make a jumper to Rc Rh & RC - R
C should go to a common if you want to power the tsta without batteries
check the installation instructions to see if there is a B-terminal see if that is the common
Posted on Jul 30, 2009
  • t1m130
    t1m130 Jul 30, 2009
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
Where does the blue wire go?
GET THE D GRAM FROM HONEYWELL USER MANUEL SOPPORT
Feb 09, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
Honeywell rth230b thermostat doesn't work
On most Honeywell Digital T-stats there is a 5 min delay built in
Oct 23, 2008 | Honeywell Programmable Thermostat Heater
Model RTH230B uses a lot of batteries
THIS TYPE has been deemed defective! changeout to a different type.
Sep 04, 2008 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
1,292 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
