Question about Xerox Office Equipment & Supplies
Phaser 6110 not printing black properly. 1st page reasonable, then faded print on following pages. Have tried two new toner cartridges but it makes on difference.
    Problem Solver:
  • 16 Answers
You must change Imaging unit.
Posted on Aug 02, 2009
Faded black and white printouts
If you remove the toner cartridge and gently shake it side to side, then reinstall it, does the problem go away, or come back after a few pages? I would suspect you have a bad toner cartridge/image unit and recommend you put in a new one.
Jan 24, 2014 | Xerox Phaser 4500 Printer
When the red light blinks on the printer what does it indicate-model-xerox phaser printer 6110
The blinking toner cartridge is low. Order a new toner cartridge. You can temporarily improve print quality by redistributing the toner. See "Redistributing Toner" on page 5.2
from the manual online as pdf: http://download.support.xerox.com/pub/docs/6110/userdocs/any-os/en/Guide_XP.pdf
Apr 06, 2011 | Xerox Phaser 6110 Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
My xerox phaser 6250 prints the first page fine then the black fades on the following pages
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Jul 13, 2009 | Xerox Phaser 6250DP Laser Printer
Magenta (yellow) unit is PAST end of life... (I have changed cartridges I still have this message. I tried to read instruction, and I got following message: Install P/N 108R00649 following the instalation)
Hi armaskopljak:
You have replaced the toner cartridge but you still have to replace the imaging unit which is the drom that the toner cartridge attaches to.
Toner Cartridge OK, Low, Empty When 15,000
(high-capacity cartridge) or
7,500 (standard-capacity
cartridge) pages are
printed (5% print density).
Imaging Units At/Near end-of-life When 30,000 pages are
printed out or when the
pixel counts are
exceeded.
A fuse in the new
imaging unit will blow
upon installation,
resetting the counter.
Verify color calibration. Clean lenses.
Xerox Part Numbers
Toner Cartridges:
Standard Capacity Yellow 016-1975-00
Standard Capacity Magenta 016-1974-00
‘ Standard Capacity Cyan 016-1973-00
Standard Capacity Black 016-1976-00
High Capacity Yellow 016-1979-00
High Capacity Magenta 016-1978-00
High Capacity Cyan 016-1977-00
High Capacity Black 016-1980-00
Imaging Units
Cyan 016-1993-00
Magenta 016-1994-00
Yellow 016-1995-00
Black 016-1996-00
Hope this helps
Jul 10, 2009 | Xerox Phaser 7300DN Laser Printer
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Continually says align print cartridges
My guess is that the color cartridge is either defective or not inserted correctly. I have a 6110 and know that inserting a print cartridge is a little tricky. If it isn't completely inserted and the top latch fastened correctly, the cartridge either won't work or produce errors.
Try reseating the color cartridge so it's inserted in exactly the same way as the black cartridge and run a print job again.
Open the following web page and go to Step three to see the instructions for cleaning the electronic contacts on the cartridge and print carriage.
Ink Cartridge Alignment Fails
Those seem the most likely causes and solutions to me. Good luck.
Oct 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
May 12, 2008 | Konica Minolta magicolor 2400 Laser...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
275 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
