All kinds of repair manuals are available here.Have a look of this may be you will get something useful.
Best Manuals
SOURCE: 1991 mazda b2200- timing belt changed
The keyway and or the dot on the crank should be line at 12 oclock. You will see a point on the oil pump housing to go by. On the camshaft the pointer will be at 12 oclock also. Use the O on the camshaft to the top at mark. Be sure to look at the dist. roter to make sure that it is pointing at the #1 spark plug wire. I could get 180 out of time. If you do it right it should start up right away. then you can use a timing light to finish it.
Good Luck [email protected]
SOURCE: installing a timing belt on 99 vw bug 2.0 -no turbo
there should be an acid mark (black mark) on gear, and yes cylinder #1 top dead center ps. make sure to disconnect distributor so it dont fire
SOURCE: timing mark-specs
ADVISE YOU NOT TO TOUCH THIS UNLESS UR MECHANILLY COMPENENT YOU NEED SPECIAL TIMING PINS & BAR FOR THIS & ARE NOT THE EASIEST TO TIME UP.
SOURCE: Timing belt posision
all the diagrams are on this page.http://images.google.ca/images?hl=en&q=diagram+of+kia+sportage+timing+belts+marks&um=1&ie=UTF-8&ei=NI01So-nJZGuswOKqon-Dg&sa=X&oi=image_result_group&resnum=1&ct=title
