Secondary air injection system P0410
First check the fuses and relays for the secondary air
Pump, if blown, replace them...otherwise, replace the pump..
See obdenginecodes.com.. emission hoseor air pump issue.. they have more possiblesolutions there
Check this out. https://www.crossfireforum.org/forum/crossfire-coupe/13707-p0410-code-check-engine-light.html
SOURCE: engine code p0410
If the air pump is working then it's going to be the one way check valve at the manifold. It's common for the check valves to go bad before the air pump, check the pipe from the pipe to the manifold too.
Before you get that far i believe there was a TSB and the warranty is 5 years to the emission system on vehicles. Looks like your close to the end of your 5 year so step on it to the dealer while you can still get a deal on this repair.
Good luck and hope this helps.
SOURCE: mazda rx8 fault code p0410
The P0410 code refers to the (secondary air system) emissions system. The AIR pump puts air to the exhaust to lower emissions. It takes in outside air and pumps it through two one-way check valves into each bank of the exhaust.
About 90% of the time that this code is set, the one-way check valves have worn out or failed and allow water (which occurs naturally in the exhaust) back into the pump. In any cold climate, especially in climates with higher humidity, this water may be more excessive. The water partially fills the AIR pump, it can then freeze. When the PCM commands the pump on, if the pump is frozen it cannot turn, thus overloading the circuit and "popping" the fuse.
A code P0410 may mean that one or more of the following has happened:
Possible solution:
This may be covered under the emissions warranty on the vehicle. If your vehicle is out of bumper-to-bumper warranty, check if the emissions warranty is still valid!
It is really only an emissions issue and won't harm your car's engine ot drivetrain. It will however mean you won't pass emission testing if you live somewhere that tests for that like I do!
SOURCE: Chrysler crossfire engine always stall
I have an excellent mechanic at my dealership.
I ran into the problem your are descrbing. Thought it was a fluke but when It got worse took it to the dealership my mechanic diagnosed it as an intermittant failure of the Crankshaft Sensor.
SOURCE: P0410 Secondary air injection system fault, P0128 Coolant temp
most ecu controlled vehicles have a 'limp home'mode if 2 or more fault codes are stored,it is designed to get your attention before damage is caused and to get you to the nearest w.shop to fix,i would have codes cleared and retest vehicle,it is the cheapest and 1st option for any shop,some late models even have excessive mileage past service interval in the 'limp' program
SOURCE: "Check Engine light"
The issue is that the system randomly checks the loop of the fuel system to confirm that it has no leaks. A missing cap is the easy one to correct. It might also be a slpit in the rubber hose that connects the fuel fill tube (on the chassis) to the one on the tank, or any other hose in the the entire fuel delivery/ fume recovery sysrtem. The solenoid that allows the engine's vacuum to be used to conduct this test can also be sticking so that after the test cycle, it doesn't reclose. Good luck
