Question about Xerox WorkCentre 385 Laser Printer
What is "fuser error
What is "fuser error" and haw ripair.
Thank you
fugaru@upcmail.ro
You have representance service in Bucharest?
Posted on Jul 31, 2009
I getting Error code 13.02.00 for HP Printer LJ2300dn
solution clean the paper sensor and service the two solenoid that's the problem inside the printer
Jan 21, 2013 | HP LaserJet 2300dn Printer
Sharp AR-405 - error code H3-00
You have an overheated fusing unit. Make sure that nothing is stuck inside the fuser unit that can cause the fuser unit to overheat. To check for any stuck sheets of paper in the fuser unit:Locate the rear door and open it. The rear door opens and drops down towards you.Look into the back of the printer. See if there is any paper or any other item stuck there that could be causing the fuser unit to overheat.If you cannot find anything jammed up or broken in the back of the printer, open the upper front cover of the printer and remove the toner cartridge. Look into the printer from the front. See if you can see anything jammed into the back area of the printer. Ifnothing appears to be jammed in the printer, the fuser unit or the main power supply of the printer will probably need to be replaced to fix this problem.
--- Here is a link to a list of Sharp error codes you may find useful in the future. Just be sure to look at the correct model number in this extremely long list:
http://www.visualhawk.vcc.ro/sharp_error_codes_en.html
I hope this was helpful to you and thank you for using Fixya! ** If this was helpful, please leave a great rating so others may benefit from this answer too! **
Sep 23, 2011 | Sharp AR-405 Printer
Sharp Am - 410 Copier & Printer " Fuser Temp" error message
My Sharp printer AM 410 is showing in the header fuser temp error what show I do
Jul 07, 2011 | Office Equipment & Supplies
I just replaced the Fuser Kit on the Office''s HP 5500 laser color printer but the error is still there and as in the instructions I never received the question: "Is this a new fuser...
Here is the instructions to reset the fuser maintenance count:
HP Color LaserJet 5500/5550 Maintenance Code Reset Instructions
  1. Press the ? button until the display reads "CONFIGURE DEVICE" and press ?.
  2. Press the ? button until the display reads "RESETS" and press ?.
  3. Press the ? button until the display reads "RESET SUPPLIES" and press ?.
  4. Press the ? button until the display reads "FUSER" and press ?
This should reset your printer and clear the error message.
I hope this helps, if so please rate my solution,
BuddyMc
May 09, 2011 | HP LaserJet 5550 Printer
I get a printer error message: "50.2 Fuser Error Turn off then turn on." I have done that but I get the same message again and again .. Could you help please ?
I not sure what machine you have, if you can inform us that would help at little bit, as to find you a part number. However what this 50.2 is telling you is the fuser is bad. You can re-seat the fuser, and the connections to the fuser. Most likely you will need to replace the fuser.
What does the fuser do?
The fuser, fuses or bonds the toner to the paper at a very high temperature.
Jan 14, 2011 | Office Equipment & Supplies
Error msg. "50.1 Fuser Error" Turning printer
Hello Pls replace the fuser with new one your problem will be resolved if problem persists then replace the dc controller bord.
Oct 28, 2010 | HP LaserJet 8150dn Printer
There is a error code is E00014-0000,how to solve it , please help me
This failure usually occurs by the fuser unit is locked. usually because the ro-liner pressure roller lock up, cleaning the caul of the fuser roll it up .. fuser unit generally does not rotate properly and adequately lafurza stumbles ... finally verify the dc motor control.
Aug 11, 2010 | Office Equipment & Supplies
Canon np1010 fuser assembly repair help I got an E 0 error code. Machine won't start. What is wrong? And where do I get replacement parts. Thank you all in advance. Tom
Hi Tom, The error code means that you have a problem with the fuser unit. It means the fuser is not warming up correctly. I would say that you need a new fuser lamp.. It most likely looks like a candy cane. You canfind it on the web. But, that is a very, very,very old copier. I was factory trained on it 20 years ago. It may not be worth repairing. It takes alot of work & taking the copier half apart & hope you get it back togather right... Good Luck
Feb 06, 2010 | Office Equipment & Supplies
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
Xerox WorkCentre 385 Laser Printer Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
