HELP IS SOMEONE USING MY WIFI CONNECTION
When my Netgear router DG 834PN IS ON OTHER PEOPLE ARE SHOWN IN THE NETGEAR WPN 111 SMART WIZARD NETWORK TAB I HAVE SECURITY BUT AM I SAFE
    Problem Solver:
  • 14 Answers
You are safe as long as you have all the security measures enabled on your router. What you are seeing is people that are in close anough range that has their own wireless network also. Mine will pick up as far as 5 houses away from where I live at. There are several here. Hope this answers your question?
Posted on Nov 25, 2007
The wifi interface is not identifying the new router. How do I change this?
You do it via a computer that is also on the same network by using its IP Address.
https://kb.netgear.com/119/How-to-configure-your-NETGEAR-router-for-cable-internet-connection-with-Smart-Wizard
Oct 06, 2017 | The Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
I lost my password to my netgear. How can I retrieve it?
Go to NETGEAR Router.
After connecting the Router into your network, you must configure it. You can do this using the Smart Setup Wizard -- where the wizard will attempt to auto-detect the type of Internet service you have through your ISP -- or you can configure the router manually. It is recommended that, if you aren't used to setting up Internet connections, you let the Smart Setup Wizard do some of the work for you.
To configure the router, you'll use the information that you filled out earlier in the Installation Guide.
To get started:
  1. Select Yes if you want to use the Smart Setup Wizard.
    or
    Select No to configure the router manually.
  2. Click Next.
Nov 06, 2010 | NetGear WGR614 Router
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
I have a Netgear WPN 111 dongle on a stand alone PC. It worked with my Netgear G router. I have now changed to a Netgear Router N300. My Laptop connects as does Iphone and Ipods but the Netgear dongle...
As u have upgraded ur router setup ..
And u have tried all possible troubleshooting steps..
Please upgrade the adapter drivers using
http://kb.netgear.com/app/answers/detail/a_id/12520
And after upagrading the drivers ,
Uninstall the adapter and reinstall it ..
I hope it will be connected ..
Jan 07, 2010 | NetGear WPN111 RangeMax Wireless USB 2.0...
I can't get AOL to set up my Netgear DG 834PN. All wires are OK lights are on but I keep getting an error message at the end of the sut up wizard.
You can try first resetting the router , to do this press and hold the reset button of the router for 15 seconds while power is ON and then after that run again the setup cd of the router..........
Nov 03, 2009 | NetGear DG834PN Router (DG834PNAU)
Airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Jul 08, 2009 | Airlink AR430W Wireless Router
Netgear wpn 111 on windows xp - "connection failed firewalled"
Check what security encryption is being used on the wireless network. Also, if you are using MAC filterning on the wireless network then disable it and then try connecting. Moreover follow the steps below to connect to the wireless network:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
May 10, 2009 | NetGear WPN111 RangeMax Wireless USB 2.0...
Still can't get access to the Router
By your post/description that the wizard starts @ 192.168.1.1 and it can identify your Internet Connection indicates that chances are, there is nothing wrong with your Netgear RangeMax WPN824 Router. Clicking on the Next tab does not make your browser go to the subsequent page is perhaps a problem with your browser and not with the router. You can try tweaking your browser:
• In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
• In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings", OK, Advance tab, check Use HTTP 1.1 through proxy connections.
• In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Alternately if this doesn’t work, try manually configuring your PC’s Network settings:
Click on Start, Control Panel, Network Connection, right click on the networking icon (that is used to connect to the router; WiFi or LAN). Click on Properties button, highlight Internet Protocol (TCP/IP), click on properties button (mid right). In the General tab:
• tick "Use the following IP address"
• Enter values as shown below -
IP address: 192.168.1.201 (201 can be any number from 2-254 that is not in used by any other PC in your Network)
Subnet mask: 255.255.255.0
Default Gateway: 192.168.1.1
DNS servers: as provided by your ISP
click on OK, OK, Close.
Additionally, you can try right clicking on the Networking icon (bottom right side) in your Systems Tray and click on Repair.
Worst case is you try and do a hard reset of your Netgear RangeMax WPN824 Router by pressing the small Reset button at the back or bottom for a couple of seconds or till the LEDs flashes. Pls be reminded that a full/hard reset will revert all router’s configuration to factory default.
Should you still need the setup files, they are available at the NetGear site here (depending on the version number). Further manuals, instructions and other documents for this router is available here.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 14, 2007 | NetGear RangeMax WPN824 Router
Computers & Internet Logo
274 people viewed this question
David Payne
David Payne
