Question about OKI C3530N Color MFP Printer
I have a C3530 MFP and it won't print because it says check toner cartridge black. Toner Sensor Error
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Toner sensor error is related to the agitator inside the toner cartridge, it occasionally falls out of its housing so it does not move the toner sensor which is the white plastic piece that moves up and down on the coloured handle, the toner sensors themselves see this white flag if it doesn’t move then the printer thinks the sensor is broken so toner sensor error is flagged and if the flag moves too quickly the machine thinks the toner is empty. To resolve the issue your printer is facing with please check that toner lock lever is in position and follow the following procedure---
Press the cover release and open the printer’s top cover fully. Make sure the Toner Cartridge in question is correctly positioned and the right hand clip is pushed back. While holding it by its top centre, lift the image drum, complete with its toner cartridge, up and out of the printer. On the Right hand side of the toner look for a sensor patch, make sure this is not dirty. If it is dirty clean it with a soft object such as cotton wool. Now look inside the printer opposite to where the sensor patch would sit. There is a black square with a sensor located inside and check that this is not dirty. Now replace the drum and toner, and close the printer cover. Try to print a test page and it will start printing normally.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 30, 2009
C544dn printer - getting code: 941.02 service magenta TMC sensor
Please try the steps provided below.
Step Action 1
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page.
Did the error message return?
Yes: Continue to Step 2.
No: The error is resolved. 2
Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Power on the printer/MFP again and print a test page.
Yes: Continue to Step 3.
No: The error is resolved. 3
It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
Did the error message return?Yes: Continue to Contacting Lexmark.
No: The error is resolved. If the toner and/or developer were not near the end of their working life.
You can also refer to this link: http://bit.ly/kecjEM
Jun 07, 2011 | Lexmark C544dn Laser Printer
THE 942.02 Service Yellow TMC Sens message is in the screen. What does it mean. It will not let me print
Error indicates a problem with the Cyan toner cartridge/developer. Try the following steps:
Power off the printer/MFP and open the toner access door. Reseat all of the toner cartridges. Power on the printer/MFP again and print a test page. Did the error message return? Power off the printer/MFP and remove the developer unit for the color specified in the error message, and then reseat it. Try printing another test page, verify if you're still getting the same error. It is possible that specified color's toner cartridge and developer unit are defective. If you have a replacement toner cartridge and developer, install them as a test and print a trial page.
For further assistance, please contact Lexmark Technical Support Center.
Jan 27, 2011 | Lexmark C540N PROD SPECS TBD Printer
Invalid Black Toner Xerox Phaser 6110 MFP
reload the driver again and if it persists, change the toner
Jun 23, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
OKI 3530 MFP Service call: 150
Your error 150 is the toner sensor board not making contact with a drum and therefore not blowing its fuse. Remove the Main board and you will find the toner sensor board behind it. It has a lot of metal contact springs and you will most probably find one is out of position and just requires removing and refitting. If still not working the part number for the board is: 43614901 OR-Board-PRS
Good luck.
Jul 09, 2017 | OKI B4350 Laser Printer
OKI C3530N Multifunction Printer
Check the left side of the drum cartridge.
There's a little door that may be stuck closed.
Carefully push it open with a small screwdriver.
Oct 31, 2008 | OKI C3530N Color MFP Printer
Error message after installing new tonner
Check the little switch/door on the left hand side of the drums.
This has worked successfully for me.
Symptom:
After replacement of a C3530 Image Drum, the message, "Toner Sensor Error" is displayed.
0.10a?openelement&fieldelemformat=gif
Cause:
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Resolution:
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Oct 30, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Toner sensor error on an Oki C3520 Laser
Check the little switch/door on the right hand side of the drums.
Symptom:
Cause:
Resolution:
Oct 18, 2008 | OKI Electric Industry C3520 Laser Printer
Toner sensor error after replacing cartrige...
Hopefully this will clear up a little confusion I had:
1. Follow instructions for replacing toner cartridge.
2. Remove drum from printer. Take care not to handle the drum surface. Look for a small rectangular window or depression. The window will be completely or partially blocked by a flap.
3. Use a fine pointed instrument to move the flap up, so that the sensor underneath is visible.
4. Replace the drum. The error should clear after the print engine has reset.
Sep 09, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Oki C3530 MFP
Con el cartucho instalado en su posición, tiramos de él para arriba y sacamos todo el alojamiento del mismo. En la parte derecha del mismo hay un cuadradito con una ventanilla de plástico que debe estar totalmente liberada. El problema es que ésta a veces se queda medio tapada y el sensor no detecta el cartucho. Levantar ese plástico hacia arriba todo lo que se pueda ( con algo que tenga punta, un boli por ejemplo) y volver a poner todo el alojamiento en su sitio. Suele funcionar a la primera, y si no, apagar y encender de nuevo la impresora.
Jul 16, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Fatal error 163
Fatal Error 161-Toner Sensor Error, Color:Magenta
When magenta toner sensor error has occurred
Fatal Error 163-Toner Sensor Error, Color:Black
Both are Sensor errors....You would first check the lock levers that hold the toner cartridges in, if everything is fine with them then you could possible have toner dust on the sensors. First take out the cartridge that you are having problems with, then use a dust off can and carefully clean out any axcess toner that you can see where the toner sits. there is a sensor that looks like a clear plastic or glass eye that reads the cartridges and it sometimes gets dirty.
Jan 11, 2008 | OKI C5200n Laser Printer
OKI C3530N Color MFP Printer Logo
1,092 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
