Computers & Internet Logo
C
Carol Gonzales Posted on Jan 23, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you change time and date? - Time Computers & Internet
Clive
Level 3:
  • Time Master 882 Answers
  • Posted on Apr 08, 2018
Clive
Time Master
Level 3:
Answers
882
Questions
30
Helped
212872
Points
3292
Start>Control Panel>System Date & Time.
During setup an incorrect year and time entered. how do I reset them
Setting the date and time in Windows 10
Note: Windows 10 automatically adjusts your date and time for you and only allows you to adjust the time if you disable this feature. If the wrong date and time is being set, you may need to change your time zone, or if you want to increase or decrease the time for other reasons, follow the steps below.
Right-click or tap on the date and time in the Windows Notification Area in the bottom right corner of the screen.
Click Adjust date/time.
Make sure your Time zone is set properly if your computer is displaying the wrong time.
To manually adjust the time, turn off the Set time automatically option and then click the Change button.
Setting the date and time in Windows 8
In the lower right-hand corner of the screen, click or tap the Windows Notification Area where you see the date and time.
Select Change date and time settings... in the bottom of the window that appears (shown below).
Time and Date in Windows 8
In the Date and Time window, under the Date and Time tab, click the Change date and time... button.
Make your adjustments and click OK.
Click OK on the main Date and Time window to save the changes.
MacOS
Choose Apple menu > System Preferences, then click Date & Time.
Click Date & Time, then set the date and time automatically or manually.
Automatically: Select “Set date and time automatically,” then choose the network time server for your region.
Manually: Deselect “Set date and time automatically,” click today’s date on the calendar, drag the clock’s hands to show the correct time (or enter the time), then click Save.
Click Time Zone, then set the time zone automatically or manually.
Automatically: Select “Set time zone automatically using current location.”
Manually: Deselect “Set time zone automatically using current location,” click a location on the map, click the Closest City pop-up menu, then choose the city closest to your location.
Click Clock.
Show date and time in menu bar: Select the checkbox to see the date and time in the top-left corner of the menu bar. In “Time options” and “Date options,” set how you want the date and time to appear.
Announce the time: Select the checkbox to hear the time announced, then choose when you want it announced. If you want, you can customize the voice.
How do i change the time
For Windows 10 following these steps to change the time and date:
1. Right click on the time (Normally at the bottom right-most corner of your screen, on your start bar)
2. Select Adjust date/time
3. Press Change (Button under Change date and time text)
4. Set the time/date, and press Change
You can also change your timezone, daylight savings and automatic internet vs manual time on that setting page.
Set clock on computer
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Change the date and time
Good day!
1. Point mouse to time and click > change date and time settings > change date and time > continue > select appropriate time and date > OK > apply > OK > DONE.
2. Go to bios settings change date and time > save settings
Need to change time on my toshiba laptop pc
Windows 7 and below:
Start> Control Panel> Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
Windows 8: Start> Type control and control panel will pop-up on the search list, click on that to open control panel>Date and time>Date and time will pop-up on the screen>Click on date and time to change the date and time.
DATE -TIME RESET??
What seems to be the problem with the date and time?
If you want to change the date and time settings, then you can click on the time on the bottom right corner of your screen. There you can change the time and date settings.
Or if date and time are always changing whatever you do then you would need to change the CMOS battery of your computer.
David
How do I change the time on the clock?
  1. Tap Menu > Settings > Phone
  2. Tap Time & Date.
  3. Tap Time Format, Date Format or Auto Update > Save
It's best to keep it set to Auto Update so that it takes the network time and updates for DST changes.
Hope this helps. If so, please consider rating this solution.
-best regards,
M
3answers
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Top Time Computers & Internet Experts
Thomas Perkins
Thomas Perkins
NOEL
NOEL
Are you a Time Computer and Internet Expert? Answer questions, earn points and help others
