Self partitioning hard drive
I have a emachines EL1200-o6W and need to reformat i ran my backup cd's and somehow ended up with a 9.8gb partition i cant seem to get rid of and this comp did not come with a restore cd i had to make the back up cd's and when i try to install a diffrent opperating system (vista hp) i recieve an error and it will not let me format or delete any existing partitions help please?
  • dm2630 Jul 31, 2009
    unforchantely my comp did n ot come with a windows xp installation disc and when i try to format using the fresh install of windows vista it will not let me
  • Raman Katwal
    Raman Katwal May 11, 2010
    Hi, Please backup all you data on DVD/CD's. So that later you will not suffer specially drivers and personal data. Try to reformat the C: with Windows Xp installation disc. Then try with Windows Vista installations. If any issue please mail me at katwal.raman@gmail.com with the details and steps you followed.
    Problem Solver:
  • 15 Answers
The 9.8gig is proberbly your back up system made by your cds have you tried going into bios and change bootup to dvd insert vista cd first then do clean install follow menu to delete partitions
Posted on Jul 30, 2009
Can I reformat ONLY ONE of the 2 partition on my Transcend StoreJet 25 M3 USB3.0 EHD ?
Yes you can format one of the partitions. When you have separate partitions, you device see this as two separate hard drives. When formating, it will not effect the other partitions.
Sep 29, 2016 | Transcend Computers & Internet
How to prepare Transcend StoreJet 25M3 for use with Acronis True Image 2014 backup Software ?
The disk size of 698GB under Windows is correct for a 750GB drive.
This tells you there is only one partition on the Transcend drive.
It is best to reformat the Transcend drive to NTFS, unless you need to also read from the Transcend drive using a computer that does not support NTFS.
I would expect Acronis backup inviting you to reformat to NTFS if you would try using a FAT32 drive for backup. FAT32 has a file size limit of 4GB which may impede backups.
May 03, 2014 | Transcend StoreJet Computers & Internet
Partition 2 to 1
Short answer, yes you can with the right software.
As long as your data does not fill up the hard drive partition.
I use partition wizard and use the resize then click apply.
You can clearly see where the data starts and the free space after.
Just do not resize into the data. And do not change the Primary partition. During the resizing you may have to set the new space to logical so the machine can see this partition. You may also have UN-allocated space after the resizing. You can format this to your choice. Select the the same format as your primary. You can do all of this before hitting the Apply button. The commands you give are stored as a script and launched in the order you selected them.
Link for partition wizard below. Read carefully before performing this on you machine hard drive. Be safe and back up the machine.
Free Partition Magic alternative partition manager freeware partition...
Good luck hope this helps!
Mar 27, 2014 | eMachines EL1200-05w PC Desktop
My iomega ex hd wanted to reformat. it started but i stopped it before thew end. did I loose all the info on it
Unfortunately, you probably did. However, you do have a few options to fix it.
Option 1: Recover deleted files/partitions
Download the active@ partition recovery utility and try running that. I'm not 100% sure how this program works, so you might need to look around the site for some tutorials or something to get it working, but it seems like a pretty good solution.
Option 2: Rebuild the partition.
In order to do this you need to know what file system was originally on the drive. It will most likely be NTFS or FAT32. The best way to do it is to get a linux live cd like the System Rescue CD. Download the .iso file and burn it to a disk, then boot your computer from the disk. Keep hitting enter until you get a command prompt (should say root@sysresccd$). At that point plug in your external drive and wait a minute or two, then type "fdisk -l" (NOTE: That's an "ell", not an "eye". Also, don't type the quotes). You should see some entry on there for /dev/sdb, but it probably won't have any partitions at the moment, which is fine. However, write down the size of your Type "fdisk /dev/sdb" to enter the disk formatting screen. Now type the following:
n (to create new partition)
p (for primary partition)
1 (for partition number)
default for First cylinder
7 (for NTFS partition)
w (to write changes)
Next, type "ntfs-3g /dev/sdb1 /mnt/backup" and "ntfs-3g /dev/sda1 /mnt/windows". This will mount your external drive and internal drive to /mnt/backup and /mnt/windows respectively. Type "cd /mnt/windows" then "mkdir backup" to create another folder. Now type "rsync -av --progress /mnt/backup backup/" to copy everything available in your external drive to your internal drive. Hopefully you can get your stuff back, best of luck!
Tj
Aug 22, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
How to reformat laptop
  • 1
    If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
  • 2
    If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
  • 3
    If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
  • May 05, 2011 | Computers & Internet
    How to reformat window xp
    Reformat the Hard Drive in Windows XP
    1. To reformat a hard drive with Windows XP, insert Windows CD and restart your computer.
    2. Your computer should automatically boot from the CD to the Windows Setup Main Menu.(If not, press F2 or DEL and choose first boot device CD or DVD)
    3. At the Welcome to Setup page, press ENTER.
    4. Press F8 to accept the Windows XP Licensing Agreement.
    5. If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.
    6. Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.
    7. Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.
    8. Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.
    9. You have now sucessfully reformatted the hard drive with Windows XP.
    Jan 02, 2011 | Microsoft Windows XP Professional
    I've got Aspire 6930 and the hdu's partitions have been erased. I got the factory recovery cd's. What do I need to do to restore the factory partitions?
    How was the partitions erased? Did somebody reformat the whole hard drive itself or just a partition. If the hard drive was reformatted then there's no way you can recover the factory partitions. Normally ther will be a hidden partition in the hard drive in case you want to use the recovery cds that came with it. And thru this, it will restore the factory settings on your computer on the state where you first got it. There is another option you can recover deleted partitions in case when the hd was reformatted like the stellar software, etc. but you have to buy it.
    Nov 05, 2010 | Acer Aspire One PC Notebook
    How to reformat my laptop
    1. If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
    2. Step 2 If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
    3. Step 3 If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
    4. Step 4 After the reformatting process finished and you have installed a new clean OS. Install drivers one by one and restart when it's required. Try to do it in order from basic function -> secondary ex. motherboard, chipset, graphic, sound, modem, networking, etc.
    5. Step 5 Install back all programs that you might need. If you already backup the installation programs or have the installation CDs handy, you can do this pretty fast.
    6. Step 6 Rearrange the look and customize your new operating system, refer to the screenshot you have taken earlier before the reformatting process begin if you want to get the same look and feel.
    Jun 26, 2010 | Acer Aspire 5315 Notebook
    How do u reformat acer extensa 5620
    Step
    1If you have the recovery cd, you can just pop-in the CD, select the reformat option and the installation process will continue automatically. Some laptop might have a special partition in the drive contains the operating system, drivers, etc. in case you want to reformat your laptop without the CD.
    Step
    2If you don't have the recovery CD, you usually can request one from the manufacturer. Otherwise, if you want to do a clean install, make sure you download all the drivers for your laptop, this may includes: motherboard, chipset, graphic card, sound card, modem, network card. Once you do that, put in the OS CD and start installing.
    Step
    3If you decided to do a clean install without the recovery CD, it would be best to create partition on your harddrive first, so you can have dedicated partition for operating system and backup. The next time you want to reformat your harddrive, you can just reformat that particular partition ex. C:\
    Step
    4After the reformatting process finished and you have installed a new clean OS. Install drivers one by one and restart when it's required. Try to do it in order from basic function -> secondary ex. motherboard, chipset, graphic, sound, modem, networking, etc.
    Step
    5Install back all programs that you might need. If you already backup the installation programs or have the installation CDs handy, you can do this pretty fast.
    Step
    6Rearrange the look and customize your new operating system, refer to the screenshot you have taken earlier before the reformatting process begin if you want to get the same look and feel.
    Jun 01, 2010 | Acer Extensa 5620-4020 Notebook
    Open Questions:
    6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
    Jul 23, 2018 | Best Computers & Internet
    Computers & Internet Logo
    225 people viewed this question
    David Payne
    David Payne
