Question about Gateway M-6843 Notebook
My Gaetway M-6843 used to power up, then turn itself off in about 1 hour of use, then after a half an hour, and now it will not even start up. No fans, activity, etc. All that goes on are the power and bluetooth LEDs, but only for less than 1 sec. The Laptop still charges though...I am really at a loss here, maybe someone has an idea
  • 408 Answers
Sounds like a overheated/damaged graphics card.Your ac adapter may be bad as well.
Posted on Jul 31, 2009
Startup takes hours, help?
The clicking suggests a power supply issue, a old trick I use in cases like this is a hairdryer, Try to heat (don't melt things) different boards carefully until you get a dramatic reaction, considering the brand which I do not like much less endorse, what is there to lose.
If you pinpoint the issue to one board try to locate that board.
Dec 11, 2012 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
Gateway M-6843 wont turn on
Hi
What happens when you connect the charger and try to power it on?
Does it power on?
Try replacing the battery and see what happens.
Hope it helps.Thanks!
Feb 19, 2012 | Gateway M-6843 Notebook
Sanyo plc-xt16 Projector After the projector is turned on and the countdown finishes on initial start up the projector shuts itself off within 5 seconds. The fan runs for 1 minute and then the projector...
It sounds like the lamp is going.
Do you know how many hours of use are reported on the lamp?
Many times these projectors have circuitry to shutdown when they suspect the lamp is near the end of life. Lamp hours vary and usually will go up to and even beyond expectancy, but there is occasions you can receive a bad lamp and have it blow in a matter of hours...not common but it does occur.
I hope this helps,
Magoo
Mar 09, 2011 | Sanyo PLC-XT16 Multimedia Projector
Ok so I'm fixing this Gateway M-6843 for a friend... When I turn it on it will try to boot but then it goes to a bios looking screen and says Windows Error Recovery at the top and it gives the options of...
It smees your windows having some problem. It might crash.
try to boot the PC from CD, repair the windows. if it cannot repair, then better do fresh loading.
Aug 21, 2010 | Gateway M-6843 Notebook
Gateway m-6843 won't boot
before we jump into conclusion that the motherbaord has a problem. try using first the recovery cd provided by the manufacturer. boot your computer from the cd rom and install a clean copy of windows. if same thing happen then you need to send your laptop to the manufacturer for repair if unit is still under warranty. thanks
Mar 28, 2010 | Gateway M-6843 Notebook
I've had my Gateway M-6843 Notebook for about 18 months. Since the day I bought it from Best Buy, the AC adapter port has been finicky. I'll be using the laptop with the adapter plugged in and the...
This problem can be caused by mainly two different things. It is either the AC Adapter itself and has a short in it, or sometimes it is caused by the Power Jack inside the laptop. Are you familiar with how to read a voltmeter? I can walk you through testing your adapter. If it is either issue, I would recommend trying to fix through warranty if possible, because the power jack repair can be expensive. If you need to replace the AC adapter, I recommend a genuine adapter, as universal adapters and cheap knockoff brands will cause issues with your laptop and usually not last very long.
Dec 11, 2009 | Gateway M-6843 Notebook
50v710 turns off by itself then on
Have you check the power supply,that's what it seems to me.
Jun 29, 2009 | Hitachi 50V710 50" Rear Projection...
Gateway M-6843 Notebook Logo
231 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
