SOURCE: No suction & brush will not turn when power
Check your belt. It is broken or stretched out. Replace the belt first. Should be your answer
SOURCE: Brush turns....suction low! Attachement works, no
Check for a blockage between brush and entry into dust chamber, if something has not made it's way to the dust chamber could result in low suction1
SOURCE: vacuum brushes won't turn. It still has suction.
That means that you need to replace the belt that turns the roller brush. They naturally stretch and wear and you should replace this belt yearly. Here is the belt you need and the manual which has instructions on how to change it:
Dyson DC07 Belt and Manual
