SOURCE: Samsung, american style fridge
We had a service tech service our fridge for the same problem. Although the ice that was dispensed was not as fine as crushed ice, mainly chunks. In any case, he said this is a known problem and is typically resolved by ensuring the freezer temp is not set at the maximum setting. Ours is currently now set at 3 bars and is producing cubes. Not sure if reducing the temp was the ultimate fix as he also replaced the ice maker.
SOURCE: adjusta ice cube maker not working
Have you checked if water is comming out the tubing before hookup? A valve may be close...
SOURCE: I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
SOURCE: My Samsung RS267LBBP has stopped making cubed ice. It only crushe
try emptying your ice tray out cleaning it real good then try it if doesnt work still may need board or auger motor
SOURCE: my side by side samsung RS2530 bbpfreezer is not freezing any ice
Are you taking too much ice in too short time? The freezer needs some time to freeze the water to form cubes. Another reason is that the water supply line may be blocked by air bubbles. Ensure that the water supply is adequate.
