Question about Dryers
My tumble dryer is spinning and everything but my clothes are coming out cold and half dry, how can i solve this?
  • Dryers Master
  • 1,606 Answers
Clean the vent and make sure you have good air flow to the outside . You can disconnect the vent from the dryer and dry a load of clothes . Comes out dry , vent is the problem .
Posted on Jul 31, 2009
Why is my hotpoint tcm570 tumble dryer leaving a puddle on the floor
Since no dryer I am aware of uses any liquid, I suggest you may be putting wet clothes into the dryer.
This can happen if the washer does not spin the clothes nearly dry. Many dryers have small holes in the dryer drum to let excess water flow out, I would guess that may be the case with yours.
Are your clothes nearly dry when they come out of the washer?
If not, perhaps the washer has a loose belt or has a problem with the "dry" cycle.
God bless your efforts.
Nov 02, 2015 | Hotpoint Dryers
Dryer heats, tumbles but does not dry. Exhaust has heat.
perhaps the washer is not spinning all of it out therefore making it hard for dryer
Aug 31, 2015 | Dryers
E15 error code on hoover tumble dryer
Controls
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
Motor
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
My tumble dryer doesn't dry the clothes
Check your breaker - a dryer will spin at 120 volts but needs the full 240 volts to dry. If that's not it, check your vent going outside the house and the hose coming from dryer. If its clogged, that's your problem. If not, you'll have a heating element issue which involves two separate fuses (and the element). Its best to hire someone if it gets to that point. Good luck...
Nov 16, 2009 | Dryers
I have a Maytag Dryer modle #HDE 306 it does not want to dry clothes it tumbles but will only dry with cold air
I had the same thing happen & it was our 220 breaker, evedently it will still run but just not heat because of the 220. everything else runs on 110 so try that.
Aug 08, 2008 | Maytag Dryers
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Nov 12, 2007 | Candy DQW150 Front Load Washer / Dryer
Dryer doesn't dry clothes, doesn't start right after Wash
If the machine is brand new, I imagine all you want to do is check you're using the machine correctly before you claim on the warranty. Trouble is, the design of this machine is so weird, and the instructions so poor that it's easy to get it wrong. So far as I can make out from this distance, you need to have all of: Spin Cancel: Out Half Load: In Cold/Cold: In Hot/Cold: Out Cold water supply: Available Drain Hose: Connected .... and as with most condensing dryers, you need to let it run to the end of its cycle - if you take stuff out without running the final 12 minute cooldown period, everything will come out feeling a bit clammy. If those control settings don't help, try a functional faultfinding approach. To dry properly, the machine needs to do four things at once: 1. Tumble the clothes: You can see whether this is happening or not. From your description, it sounds like this is working. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 2. Blow hot air over the clothes: You should be able to hear the fan running, and if you open the door, the air which comes out should be quite warm. If this isn't right, see if changing control settings works, but then for a new machine make a warranty call. 3. Condense the moisture out of the circulating air: If this isn't happening, the clothes don't get any dryer - they just get increasingly hot. Before making a warranty claim, all you need to do with this problem is ensure that the supplies and settings are such that cold water (and only cold water) is getting to the condenser. 4. Pump out the condensate: If you've just washed successfully, this is probably going to be working fine. If not, then you'll start to see the drum slowly filling with water. If this happens, check the filter (p12 of the manual), then get the warranty claim going. Welcome follow-on questions or news on how you get on posted as a comment to this query. A.
Jun 27, 2007 | Malber WD1000 Front Load Washer/Dryer
Keeps on cutting out on Hot drying cycle
this will be a problem with your thermostats 1 of them will have a thermal cut-out switch built onto it this thermostat needs replacing it is faulty
Dec 07, 2006 | Zanussi TC7114W Electric Dryer
Dryer seems to work, but clothes end up damp?
Corwyn, looks like the problem you are having is not with the dryer. The vent line is probably clogged up, which caused the moisture to stay inside the dryer. To make sure this is a vent problem, you can disconnect the vent hose behind the dryer and run it for one load with it disconnected. If it runs fine, then the vent line needs cleaning. Usually it needs special equipment and is very hard to do yourself. It would cost you around $90 to get a professional out to do it for you. Gendos....post back.
Dec 19, 2006 | Whirlpool LER6636PW Electric Dryer
Dryers Logo
95 people viewed this question
Top Dryers Experts
