Question about GE GSH22SGRSS Side by Side Refrigerator
Fridge & Freezer smell like a gas grille...
Hello! I just moved into a new place and have a GE side-by-side stainless steel refrigerator. For some reason, the smell of a gas grill has permeated throughout the freezer and fridge. When I first moved in a week ago, I thought someone was grilling outside but soon found out it is the fridge...any ideas what the problem is and how I can fix it?
  • 24 Answers
Do you mean it smells like propane? Or does it smell like propane exhaust (think taxi cab or fork lift)?
Either sounds pretty serious. I have heard of people using hydrocarbons to recharge refrigeration systems, though it is not the recommended method.
Do you own your residence or do you rent? Either way, call a repair man or the management of your rental right away and insist to have it inspected.
Fridges might smell like plastic or stale air if not used in awhile, but not propane/exhaust that I have ever heard of.
Posted on Jul 30, 2009
SOURCE:
GE Profile smell; cleaned fridge thoroughly twice; no relief
once you've cleaned the refrigerator, put a small bag of open charcoal in the freezer and refrigerator and leave it there until the smell goes away.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working Water works fine in the door. (GE Profile side by side)
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
gfs4
May 29, 2010 | GE Profile PSW26P Stainless Steel Side by...
Does conversion from LP gs to Natural gas on Ducane 30400040 (essentially makes it a model 30400041) require changing the inlet orofice on the IR burner ? I purchased conversion kit that included all new...
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
May 14, 2010 | Ducane 30400040 Stainless Steel Grill
Can I get a replacement door for my GE Profile Refrigerator
Warners Stellian in Minneapolis can help.
For cleaning DeBruce Polish is the answer.
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more. We buy DeBruce at debrucepolish.com.
Feb 01, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a side by side GE Monogram. When closing
the refrigerator should be leaning back enough to allow it to reclose. there are hieght adjusters behind the grill on front
Jun 12, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Ge side by side not cooling
Unplug refrigerator and remove panel on back to expose the control board. Look for burns or smell of burned board. Look at both sides and let me know if you see any problem, Thanks, Sea Breeze
Mar 19, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator Door Lost Suction
I have a GE Profile Stainless Steel side by side. I also noticed that the refrigerator side door was not sealing like it had previously. There was no "suction" when opening. I started inspecting the gasket around the door to see if this needed replaced, as I had read that may be the problem from this forum. My particular model has the grill / vent at the bottom of the door, in the front, which just pops off. I found that down by the grill my model has magnets there that match up with magnets on the bottom of the doors. I inspected this and found a foreign object had attached itself to this magnet. I removed this object and waaahlaaah the door now has suction! I was relieved to find that I didn't need to replace the gasket. Worth a try. Hope this helps.
Aug 25, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSH22SGRSS Side by Side Refrigerator Logo
455 people viewed this question
Top Refrigerators Experts
Brad Goodale
Peter Taylor
Matt Sicignano
Level 1 Expert
