Question about Toshiba Satellite M50 Notebook
My Toshiba Satellite M50 laptop wont turn on.. the battery has lost it's charge, and the AC adapter no longer seems to provide any juice. Is this likely a problem with the adapter, or the laptop itself? I've read that the Toshiba Satellite line has problems with power supply, and that this is a fairly common issue on older models. (mine is now about 3.5 years old). If it is a computer problem (and not an adapter problem), is it worth spending the money to have it repaired?
  • 408 Answers
Sounds like the ac adapter if not maybe the power jack.
Posted on Jul 31, 2009
2 Suggested Answers
2009ubuntu
  • 10 Answers
SOURCE: My Toshiba Satellite M50 laptop wont turn on.. the
I've repaired a few laptops with the same problem, check out this page on power jack repair. http://tinyurl.com/powerjackrepair
Did it run out of power when you were using it, or did you go to use it one day and it wouldn't turn on? because I've know people spill stuff on the friends/family laptop and not tell them about it.
Posted on Jul 30, 2009
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Mar 11, 2014 | Toshiba Satellite X200-AA3 Notebook
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Toshiba Laptop not charging
So confusing...Laptop AC Adapter nowadays has AUTOMATIC VOLTAGE, meaning it doesn't matter if it is 110v or 220v. Maybe you've got a FAULTY BATTERY. Remove the battery and plug in your AC Adapter to outlet and to your laptop and try to power-on.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Professional Services
09126888500
Apr 02, 2010 | Toshiba Satellite A100-S8111TD Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
My Toshiba Satellite A10 S100 Laptop will not turn on. I've tried takeing out the battery for a minute & putting it back in but it still doesn't work. There is a orange light below the "power" icon...
It sounds like the power supply inside has gone bad. If its not under warranty it will most likely cost more to fix than its worth.
Try running it without the battery and just off the AC power....if that does the same..I'd say start looking for a new one.
Aug 27, 2009 | Toshiba Satellite A10-S100 Notebook
My Toshiba Satellite M50 laptop wont turn on.. the battery has lost it's charge, and the AC adapter no longer seems to provide any juice. Is this likely a problem with the adapter, or the laptop itself?...
Jul 30, 2009 | Toshiba Satellite M50 Notebook
My Toshiba Satellite A30 laptop keeps switching off when charging. It works fine when on the battery but seems to overheat when I use it whilst charging the battery. Can you help ?
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
Jul 05, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Toshiba satelite A100 rejects AC... often.
Just to humor me, are you using any peripherals with your laptop when this happens, such as a wireless mouse, USB connections such as digital cameras? Try to take these away when recharging.
There seems to be 2 issues here.
1) Recharing batteries: To prepare the batteries for long-term use (I do not know how long you've had the batteries...try draining the batteries (both of them), and then recharging it to full 2x before using them without the AC Adapter. This should clear the problem.
2) AC Adapter only works every other day: When you swapped the power pack, was it with a new AC adapter, or another used one? Also, have you tried using a different outlet than the one you normally use? Let me know how this turns out.
Nov 17, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M50 Notebook Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
