Question about HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001
When I try to record with a mic into the Laptop...It always seems to playback not in stereo but with one side louder than the other...What can I do to remedy this situation? Am I doing something wrong?
  • HP Master
  • 32,281 Answers
The mic in the laptop is normally not a Stereo mic. and will equal sound level on both channels.
Check the audio settings to see if the left and right speakers are balanced in the middle and not set to one side.
Posted on Jul 31, 2009
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
When I record and listen to playback, I only hear the left side.
This is normal for recording. Even professionals do the same. What you need is to set your input to mono(either hardware or software), or explore your software look for effects like STEREO to MONO with some delay which I prefer for my recording. I did have a good result. Good Luck
Mar 07, 2010 | M-Audio M AUDIO MOBILE PRE - USB MIC...
When I record with the internal mic or the BA
I had that problem too. What you need to check is the input level on the right side. Turn the wheel all the way up to 100 and the internal mic should be fine.
Feb 07, 2010 | Boss Micro BR Digital Recorder
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
Audio on Dell Webcam Central And voice record isn't working
I have a Dell 1545 with Dell web cam central & I've had this issue. The problem is that Dell web cam central installs it's own microphone settings onto your laptop called something like Dell web cam Live!. This isn't the built in microphone in my laptop & maybe not yours either. You have to change the settings for your computer system & Dell web cam central. Go to start> control panel> sound> recording .. on mine there is an option for Microphone "High Definition Audio Device" ... that is the built in mic. You want that for your default & apply it. Also .. as a side note .. I disabled the web cam central Live! microphone completely from this window. Then open Dell web cam central & go to the "Record Video's" option. In the middle of this is an orange button with a video camera icon. Next to this on the same button is a little arrow pointing down .. click that. Under microphone .. choose Microphone "High Definition Audio Device" just like the sound option in control panel. I've done this & it's completely fixed. I can record videos with sound & use my built in mic in voice/video chat.
Aug 15, 2009 | Dell Inspiron 1545 Notebook
Feedback from mic on fatal1ty headset
Ive seen problems like this before ,Make sure under volume control property that the mic mute button
is ticked .
Mar 27, 2009 | Creative Labs Sound Blaster X-Fi...
Magix studio 10
the problem is you are only recording on one side if you are using only one source, try using dual mics (with a audio interface with at least 2 inputs) or just record your tracks in stereo, then change the playback prefference to mono for listening purposes, then change back to stereo before mixdown
Jul 08, 2008 | Magix ENTERTAINMENT Music Studio 10 deLuxe...
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
HP Compaq Presario F500 F700 and G6000 Motherboard - 442875-001  Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
