Question about Kenmore Washing Machines
Door won't lock shut - Kenmore Washing Machines
  • 15,935 Answers
Removing the door safety switch:
1. Disconnect the washer from the electrical supply.
2. Release the bellows from the front panel:
Releasing the bellows (door boot) from the front panel:
The front of the bellows is installed over the lip of the door opening in the front panel and held in place by a spring loaded wire loop.
3. Open the loading door.
4. Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows.
5. Pull the bellows off of the lip of the front panel.
6. Remove the (2) screw holding the switch assembly to the front panel.
7. Pull the switch assembly into the door opening and unplug the electrical connectors.
Install is the reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
2008 GMC Sierra pickup. Driving and all of a sudden it shut off then turned back on; the doors unlocked then locked again. Now it won't do anything. Checked the oil and it was empty - no oil at
Running with no oil is death for the motor ( Seized). When the alternator stopped working because the engine stopped the door lock control opened the door locks as it said you were below the required speed to have them locked
Mar 31, 2013 | 2008 GMC Sierra 1500
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Power door locks won't work and the instrument pnnel lights won't turn on. I replaced blown fuse a 20mp one in position 14 I believe. worked ok till I tried to lock the doors, the fuse blew
Hello. Try looking at the black earth that goes from the drivers door and into the A frame which is covered in a rubber sheath. The wire can break after opening and shutting the door over several years and as it's normally the thicker wire is more prone to break. Also check the other wires visually for any chaffing and tugging on each wire. If more electrical parts start failing, air con blowers etc it will be an earth. Hope this helps
Nov 03, 2012 | 2002 Dodge Neon
Washer won't stay running error code DS
I am wondering if your error code is DS and not D5, which would indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not believe the door is closed and/or locked, so it shuts down the machine.
Oct 16, 2012 | Washing Machines
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Dome light in pontiac won't shut off
is the switch in the door bad?leave the key in the ign does the key chime go off before you open the door i think that model the switch is built into the lock assembly
Apr 26, 2012 | 2005 Pontiac G6
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
Security lites won,t shut off have to disconnect battery
Try turning the door key in the rear door hatch lock, lock-unlock-lock. That should shut down the factory security system.
Jan 13, 2011 | 1995 Jeep Grand Cherokee
Washing Machines Logo
69 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
