SOURCE: Softener tray filling with water
open the dispenser all the way,place your finger towards the back left of dispenser.you should see a tab,depress the tab and pull entire dispenser cup out.the bleach and fab soft part of the disp has a removable tray.clean all pieces out including the long shafts on the insert.you will more than likely find a build up of softener,this breaks the siphon and does not allow the water to drain out.good luck
SOURCE: The fabric softener and bleach tray won't drain
clean the caps sometimes they get clogged and cannot syphone
SOURCE: after cycle, water is in the softener and bleach
Water floods the dispenser compartments at the start of the cycle to dilute/dissolve the softener, bleach, and detergent. The reason why water is in the compartment after the cycle is that, the detergent, the softener, and/or the bleach does not flow into the tub properly. It's either the dispenser assembly is clogged or excessive amount of detergent, softener or bleach is used. Clean the dispenser assembly and make sure to use no more than two tablespoons of powdered HE detergent or one-and-a-half ounces if liquid HE detergent.
SOURCE: I just moved into a
The dispenser asm. has a tab in the rear of it,find it and push it and the dispenser tray will pull out to be soaked and cleaned in the kitchen sink. vinegar could soften it up before going at it with a soft scrub brush.
I hope this has helped you,
Gene
SOURCE: kenmore frontloader fabric softener dispenser is clogged
There should be pins located somewhere on the dispenser or a grey thing located inside the dispenser, push it down and that will release the dispenser from the washer. Afterwards you can put in in the dishwasher, this should clean out any clogging residue.
