Re: Water continues to run after ice tray is full. I...
You either have a defective ice maker or dual water control valve. Let me know your model number so I can help you better. Please rate me, Thanks, Sea Breeze
OK is the bin full of ice to where the ice stops making ? and is the water running over into the ice bin. If this is whats happening then cut the machine off, If water is still coming into sump tray then pull the water inlet valve and replace it. If the water stops when you shut the machine off then check the water float or sensor since i don't know what model you have, If float then replace it , if probe sensor then replace it. Now if there is no water running over into ice bin during freeze cycle then nothing is wrong ice machines use a lot of water every time it go's into a harvest it dumps the water in the sump tray.
The valve could be bad if the water continues to run and overflow or if the valve is slow to close allowing it to overflow. If it just fills and cuts off quickly then the ice maker may be the problem. On some ice maker you can take off the plastic end cover and look for the + -. Turning it towards the - is less water. -
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
The water inlet valve may be staying open. It's on the back where the water supply is connected. You
can swap the wires on the dual water inlet valve and disconnect the water line
at the valve which goes to the ice maker. When you try the water dispenser the
water will come out there. When you stop the water dispenser, if the water at
the valve doesn't stop, the valve isn't closing so you'll need to replace it.
Really sound to me that the water control valve is defective and will not close. Pull refrigerator away from wall and on the water control side for the ice maker disconnect the two wires. If the water continues to flow the valve is stuck open and will need to be replaced. Let me know, Sea Breeze
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
The ice maker water fill solenoid may be leaking by and needs to be replaced. If you disconnect the water line from the solenoid and you see it continues to flow water then that valve is not seating properly. Another slight possiblility is the ice maker motor module gear is stuck in the fill position. See the attached link for a diagram. If the geared wheel just happens to get stopped in the "fill" position it will fill with full force water. If there is only a trickle of water then the soleinoid valve is the more likely source of the problem.
http://www.partselect.com/Schematics/Maytag/AA56-20.gif
http://www.partselect.com/Schematics/Maytag/AA56-16.gif
Sounds like the water fill solenoid valve is leaking by. You will have to change that solenoid valve if the water continues to drip into the ice maker tray after a normal fill cycle.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=JCD2295HES&mfgModelNum=JCD2295HES&fkMfgID=1
U-Line Model No. WH98 S/N 98-103726
